Larger throttle body?
Old 11-25-2011, 10:24 PM
dmelvin's Avatar
They don't come with a cable driven throttle body, you'd have to pick up one of Nick William's or some other company's 90mm throttle body. The NNBS trucks use the cathedral port heads, so that will be fine. there are some fueling modifications you have to do though. Read through that thread neilowns posted... probably from using the search function.
Old 11-25-2011, 11:10 PM
traveling mod
andrew383's Avatar
Originally Posted by SamuelsonMotorsports
Do they have that intake with a cable operated TB? I wouldn't mind doing the swap so long as everything bolts up and I can keep my cathedral port heads.
And of course, it needs to be able to support 600hp.
I know nothing of the tbss/nnbs yall speak about.
You'll never hit 600hp with either stock manifold,its just to much power..
For 600hp your def gonna want the F.A.S.T. LsxRT manifold and there 102mm throttle body..You would be leaving alot on the table if you didnt
Old 11-25-2011, 11:59 PM
nonnieselman's Avatar
Stock48 made 1100 rwhp on the stock 2003 intake / throttle body. But with a turbo
I say go woth the TBSS setup and the 90mm. See what improvements that gives you.
Old 11-26-2011, 12:42 AM
GMCtrk's Avatar
SweetS10v8 has extensive dyno time with the FAST intake, and mentioned via PM that the 102mm TB was only good for 2.5hp over the 92mm TB on a 750 HP engine. And the 102 TB is harder to tune as well due to loss of resolution at low blade opening due to the sheer size of the opening. Conclusion: 92mm is probably the better choice for almost everyone.
Old 05-23-2022, 08:20 PM
Registered User
Imthedevildog's Avatar
you can definitely hit 600hp on a stock intake manifold lol
Old 05-24-2022, 08:20 AM
shakenfake's Avatar
Received 1,174 Likes on 894 Posts
@Imthedevildog What else can you do 11 years later?
Old 05-24-2022, 09:07 AM
DuNnO
RDF1's Avatar
Better late than never.
blownss27
08-14-2020 08:27 AM
chvy=power
10-20-2015 09:08 AM
murderedSS
27
10-12-2015 11:13 AM
99bluefirebird
09-17-2015 08:05 PM
bisqikss
09-08-2015 03:35 AM
Quick Reply: Larger throttle body?
