Larger throttle body?
Old Nov 25, 2011 | 10:24 PM
dmelvin's Avatar
They don't come with a cable driven throttle body, you'd have to pick up one of Nick William's or some other company's 90mm throttle body. The NNBS trucks use the cathedral port heads, so that will be fine. there are some fueling modifications you have to do though. Read through that thread neilowns posted... probably from using the search function.
Old Nov 25, 2011 | 11:10 PM
andrew383's Avatar
traveling mod
Originally Posted by SamuelsonMotorsports
Do they have that intake with a cable operated TB? I wouldn't mind doing the swap so long as everything bolts up and I can keep my cathedral port heads.
And of course, it needs to be able to support 600hp.
I know nothing of the tbss/nnbs yall speak about.
You'll never hit 600hp with either stock manifold,its just to much power..
For 600hp your def gonna want the F.A.S.T. LsxRT manifold and there 102mm throttle body..You would be leaving alot on the table if you didnt
Old Nov 25, 2011 | 11:59 PM
nonnieselman's Avatar
Stock48 made 1100 rwhp on the stock 2003 intake / throttle body. But with a turbo
I say go woth the TBSS setup and the 90mm. See what improvements that gives you.
Old Nov 26, 2011 | 12:42 AM
GMCtrk's Avatar
SweetS10v8 has extensive dyno time with the FAST intake, and mentioned via PM that the 102mm TB was only good for 2.5hp over the 92mm TB on a 750 HP engine. And the 102 TB is harder to tune as well due to loss of resolution at low blade opening due to the sheer size of the opening. Conclusion: 92mm is probably the better choice for almost everyone.
Old May 23, 2022 | 08:20 PM
Imthedevildog's Avatar
Registered User
you can definitely hit 600hp on a stock intake manifold lol
Old May 24, 2022 | 08:20 AM
shakenfake's Avatar
Shlumpt
5 Year Member
@Imthedevildog What else can you do 11 years later?
Old May 24, 2022 | 09:07 AM
RDF1's Avatar
DuNnO
5 Year Member
Better late than never.
blownss27
Aug 14, 2020 08:27 AM
chvy=power
Oct 20, 2015 09:08 AM
murderedSS
27
Oct 12, 2015 11:13 AM
99bluefirebird
Sep 17, 2015 08:05 PM
bisqikss
Sep 8, 2015 03:35 AM
