Larger oil filter
Maybe a stupid question to some but is there a larger/longer oil filter that can be used on our trucks.
FYI i would think that more filter media and slightly greater capacity would be benificial.
Thanks BLAKE
Thanks BLAKE
The Mobil1 M1-206 is longer than the AC Delco filter that is available for our trucks. It's about the same size as the old PF-59 that GM used to offer for us. What's the factory filter now, PF-46 or something like that? I know that it's about an inch or so shorter than the M1-206. I think that the K&N filter is also longer than the Delco. Both the M1 and the K&N are a little pricey, but they're good filters. Not sure how big the Amsoil filter is...
21522mp for the plastic wrapped cheap napa number
21522 is the cheap napa number
91522 is the spin-flo number - with anti drainback
1522 is the gold (wix) - with anti draim back
51522 is the wix number - with anti drainback
PH3675 for a fram
PH3675 for a fram
That's right, the Wix ones are longer, and the Delco ones used to be before they discontinued them. They actually used to have a high performance filter that I used, with a synthetic element in it, it was a "UPF-59", then they stopped making them. So I switched to the regular PF-59 and they did away with those. When I ran out of the stock of those that I had I swiched to the Mobil1 filters. I may give the Amsoil filter a whirl if I find out that it's the longer size like the Mobil1, Wix, etc.
Amsoil has a filter that is longer than the one they spec EaO32.
I use an EaO64 which crosses over to the PH 59 I think. It is definitely longer than the EaO32 and much easier to get a filter wrench on. It has the anti-drain back valve as well.
