L33- Future turbo- College school Build
Old Mar 9, 2018 | 05:40 PM
  #31
1994Vmax's Avatar
The exhaust valves in a 243 are the same 1.55" valve used in a 317. Why not scab the 243's and give them the old 317's to send shrapnel into them lol. Being an 09 you still have the 9.9:1 setup.... might help it live a minute or two longer lol.
Old Mar 10, 2018 | 02:43 AM
  #32
swathdiver's Avatar
5 Year Member
While I have yet to put hands on my 243/LC9s valves, all of my literature says they are 1.575 versus 1.55 for the 317s. Now that you mention it, I see both. Was there a change in 2010 or is the larger size an error?
https://summitracing.custhelp.com/ap...id/4854/kw/lc9
http://www.enginebuildermag.com/wp-c...0000054947.pdf
Old Mar 10, 2018 | 08:07 AM
  #33
1994Vmax's Avatar
My buddy runs a cylinder head rebuilding shop and I supply him a lot of 243s and 799s... plus whatever else. They all have a 1.55" exhaust valve in them. They could benefit from a larger valve as by the time they are cut to fit the seat the edges are knife edged.. And you see it becoming an issue on higher mile stuff right from GM. The older 706 and 862 heads use the same exhaust valve too just with like a 1.89" intake. The only normal truck heads with bigger exhaust valves are the L92's.
Old Mar 10, 2018 | 09:46 AM
  #34
swathdiver's Avatar
5 Year Member
Thanks for the correction!
Old Mar 15, 2018 | 06:15 PM
  #35
trxmxzx's Avatar
13 Second Truck Club
Alright I’m in class right now and need some help, what cam gear set does this thing need? 4x? The tech bought the cam in 3-bolt and it had a single bolt
Im not up to par with newer than gen 3 stuff
Old Mar 15, 2018 | 08:21 PM
  #36
swathdiver's Avatar
5 Year Member
Are you putting in a stock stick or a Gen III camshaft? He can use the 3-bolt sprocket.
Old Mar 15, 2018 | 09:33 PM
  #37
trxmxzx's Avatar
he bought a 3- bolt
from everything I recall of 58x needs a 4x cam sprocket
i posted that to confirm my correct thinking on it so they can have it by next week
Old Mar 16, 2018 | 02:12 AM
  #38
swathdiver's Avatar
5 Year Member
Sprocket needs to be #12586481 and the old style dampener is more reliable.
Old Mar 16, 2018 | 01:55 PM
  #39
trxmxzx's Avatar
thank you!!
Old Apr 21, 2018 | 09:53 AM
  #40
trxmxzx's Avatar
So a update.... semester is coming to a end, a lot of debates with this silly project. Truck oil pan I told them would not fit indeed would not work, waited two weeks for a new one, flex joint between cross over to turbo was mentioned (over ruled again) to many chiefs on project.
Car still needs a lot... got trans though but no flex plate or converter :/ need accessory’s they are lost. So here’s as far as it has got
New car pan
