L33 D-shaped Ex port into round header openings=good or bad?
Old Jun 22, 2006 | 03:57 PM
Moddoo's Avatar
Default L33 D-shaped Ex port into round header openings=good or bad?
I recently found out that the L33 head has D-shaped exhaust ports.
Since every header I have seen is built with round ports, I am curious how this will affect the truck.
Does anyone know if this will make much difference?
Attached Thumbnails L33 D-shaped Ex port into round header openings=good or bad?-img_2555sm.jpg
Old Jun 22, 2006 | 06:26 PM
Yelo's Avatar
Don't worry about it...the LS6/LQ9 heads are that way and MOST SBC heads are like that, until someone invents a D-shaped pipe to mate to it I wouldn't even think about it anymore.....
Old Jun 23, 2006 | 06:54 AM
Moddoo's Avatar
I havent seen any gm headers D-shaped, but mustangs have some available.
Someone is taking the time to match the shape, there must be a benefit.
how does the D-shaped port help the head?
here are a couple pics of a stang head and headers.
I know the head is ported, but it was the only decent pic I could find.
Attached Thumbnails L33 D-shaped Ex port into round header openings=good or bad?-stang-headers.jpg   L33 D-shaped Ex port into round header openings=good or bad?-ex-port.jpg
Old Jun 23, 2006 | 03:47 PM
BVVHO's Avatar
Default D Port exhaust on L33 heads
I read on another forum that MELEROSE makes headers with the D port for fast burn and vortec heads.
Old Jun 24, 2006 | 07:58 PM
Silver LT's Avatar
Default Gasket matching
Lay the gasket over the header and see if there are any sections where the header tubing extends into the port. If so, carefully grind the tubing to match - just make sure you don't grind through the weld. If the header tubing is bigger than the port, everything is fine. Going smaller to larger is good, going larger to smaller is bad (causes lots of tubulance, which decreases flow) In the old days, this was called gasket matching.
ARC
57
Feb 21, 2022 10:54 AM
custm2500
Jul 25, 2015 10:05 AM
jmarkway
Jul 18, 2015 09:23 PM
rojeho
Jul 12, 2015 06:10 PM
GM1697
Jul 9, 2015 01:55 PM
