killing a dead horese
Old Jun 29, 2006 | 11:12 AM
ltn's Avatar
ltn
Default killing a dead horese
Ok i know people say that e fans are good and i believe they are as well and have a set. However, has anyone actually towed heavily with the ls1 fans in heat. The reason is i was just looking around and found something on gm-trucks.com and people were saying that the fans would not cool enough under heavy towing and heat. They say the stock clutch fans are better. just wondering thanks.
Old Jun 29, 2006 | 04:10 PM
shandy294's Avatar
I think that's true from what I've read here.
Old Jun 29, 2006 | 04:14 PM
thunder550's Avatar
High on diesel fumes
I have been battling overheating issues while towing ever since I installed e-fans. I can keep temps relatively under control but it's still an issue.
Old Jun 29, 2006 | 04:15 PM
ltn's Avatar
ltn
now what do u guys tow, are they big trailers or what?
Old Jun 29, 2006 | 04:19 PM
thunder550's Avatar
about 6000 lbs in my case
Old Jun 29, 2006 | 05:04 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
WOnder how the 05s and up handling towing then. Somethin sounds wrong with ur setup thunder.
Old Jun 29, 2006 | 05:33 PM
thunder550's Avatar
Well it seems to be consistent, and I have the 05 truck fans. I originally started seeing issues on the stock 5.3 with the Radix, then did a cam swap and smaller pulley, still having issues, then the 6.0L swap, still having issues. Not sure what the deal is, but the issues are the same on a couple of different setups and the radiator has been drained and refilled probably 3 or 4 times in the past year.
Old Jun 29, 2006 | 06:09 PM
ltn's Avatar
ltn
well it sounds like ur car is pretty heavily modded so maybe thats why ur having issues. im just wondering about people who tow with a basically stock setup.
Old Jun 29, 2006 | 06:17 PM
99Silver6.0's Avatar
Id say the 05 fans or the Flex 292 would be a better idea. LS1 fans press right up against the radiator. If you think about it, all that does is pull air across 2 small areas the size of the fans. And they are kinda small fans. Versus the Flex 292's actually having a shroud. Which can create some sort of air pattern across the entire surface of the radiator. The 05 fans are much bigger than the LS1 fans too. Because of the 34" radiator they could do that. You guys with the 05 fans having problems too????
Old Jun 29, 2006 | 06:19 PM
Wilde Racing's Avatar
How do I change this text
Glad to finally hear I'm not the only one that had a overheating issue with e-fans. Though I had lt-1 fans. I was hopping the set of 05 fans I have sitting next to my truck and a bigger radiator would help. I guess not
Thunder550, how hot was it outside when you where towing?
