just won a 5.3...?'s
Old Jun 12, 2005 | 09:48 AM
litreddevil's Avatar
Banned
A Shop Might Only Charge You A Bill May Be 2 But Still Not Bad
Old Jun 13, 2005 | 02:46 PM
vortec_7's Avatar
does anyone know the bolt sizes for the motor mounts, transmission crossmember, the bolts that attach the tranmission to the block, and the transfer case to the transmission? the driveshafts? how about the bolts that attach the exhaust manifolds to the rest of the exhaust? are there any specialty tools ill need to pull the drivetrain or any hard to reach spots?
or does anyone have a link to a service manual where i can find out this info?
how about a good place to attach a chain to hoist out the motor/tranny?
this is on a four wheel drive 2000 chevy 1500.
thanks, i appreciate all the help i can get.
Old Jun 13, 2005 | 04:14 PM
David Cairns's Avatar
Originally Posted by vortec_7
...when I go to take it out. I'm bringing an assload of tools with me.
Are you sure you can't find a better way to bring the tools along?
Old Jun 13, 2005 | 04:43 PM
vortec_7's Avatar
how could you beat the convenience, ergonomics and storage capacity of an assload?
Old Jun 13, 2005 | 05:32 PM
Wilde Racing's Avatar
How do I change this text
I just pulled my Engine.
For the exhaust You need a 15mm deep and a 12" extintion.
Also the bellhousing bolts are 15mm, with 13mm nuts for looms and trans dip stick. For the top bellhousing bolt you can ether fight it, lowwer the trans/engine assy down enough to reach from the ground or pull the intank.
also you will need a strap wrench or big chanel lock pliers and a 15"+ adjustable end wrench to pull the fan.
Disconnect the battery and bleed the fuel from the line on the intake manifold. (after you are done under the truck)
Take a GOOD (as in quality) set of allens with you for the torque converter bolts. also a fuel line tool is needed.
There are thee ground straps on the back of the block near or on the left head.
You will also need a P/S puller, and a floor jack for the trans.
I used lifting links installed in the heads and a gange chain to lift it out.
I'm sure there is a few more tools needed, if you have any other questions let me know, I'll try and answer them.
Old Jun 13, 2005 | 06:20 PM
vortec_7's Avatar
thank you so much!!!!
i was planning on pulling the whole drivetrain together if i can. are there any problems with this? its a 4 wheel drive truck so ill probably just take the driveshafts off and the transfer case then lift the engine and trans out. do you think i could disconnect the p/s pump at the lines instead of pulling it? im probably only going to run an alternator when i get it set up in my rx-7, so i wont be needing the p/s. thanks again.
Old Jun 13, 2005 | 09:10 PM
I think you will have better luck droping the trans first. the Engine sits way under the cowl of the cab, not saying it wont fit cause I dont know but theres not a whole lot of room around the trans. I would bet the transfer case will have to come of the trans. The bellhouseing bolts arnt that hard lol.
Old Jun 13, 2005 | 11:34 PM
CashDudeHomie's Avatar
If the truck is wrecked just cut the whole front end off, it will make it much easier! I pulled mine without taking off the PS pump. I did leave the A/C hanging though, so I wouldn't have to discharge it. One of those bolts is tight against the frame. Also since it's a 4wd, it shouldn't be as hard since I think they come with a slight body lift. Just cut the fuel lines since you won't need em. Also you might need a buddy to hold the crank bolt while you loosen the converter bolts. Be careful because they strip easy. Mine were 8mm "Allen" style. A metric deep socket set should do it. 95% of the bolts are 13 or 15mm anyway. You will need to bolt the chain or sling to the engine block with strong bolts. I don't remember the thread size though. Someone can chime in if they know it. What kind of price did you get since you have to do the labor yourself?
Old Jun 13, 2005 | 11:36 PM
Oh yeah, behind the intake manifold on the left side, there's the oil pressure sender sticking out. Be careful! It's a flimsy plastic piece of junk but it cost me and hundreds of other people on here 50 bucks to replace.
Old Jun 14, 2005 | 09:36 AM
vortec_7's Avatar
yeah the truck isnt wrecked, theyre supposedly parting it out because the transmission's reverse went out and they screwed the back of the truck up and broke the windshield loading tree branches into it. i was a little cautious about why the hell they would part it out just because of this but i get to hear it run since its still in the truck and that makes me feel a little better.
i shouldnt have to remove the torque converter, im taking it all if i can . its a woman and her husband selling it and they dont seem to know much about cars and im hoping thats why im getting the drivetrain for 400 bucks.
dsbodley
Nov 14, 2015 09:46 PM
wickedRCSB
Oct 30, 2015 09:45 PM
nabozny21
Oct 17, 2015 07:47 PM
old motorhead
Sep 29, 2015 08:22 PM
trxmxzx
Sep 29, 2015 07:42 AM
