This just looks wrong...?
Old Oct 12, 2009 | 12:13 PM
00ChevyScott's Avatar
Wearin' da big hat
Originally Posted by GMCtrk
blue loctite seals just fine. I ha literally the whole bolt covered lol.
I would NOT have used red loctite on the rocker arm bolts. You may never get them out now without damaging the threads
I used red and they came out just fine after almost a year? The easiest way to break the hold is to tighten before you try to loosen it.
Old Oct 12, 2009 | 12:21 PM
dlt76028's Avatar
i never sealed mine either...
Old Oct 12, 2009 | 12:36 PM
chevrolet all the way's Avatar
mine arent sealed...
GMCtrk's Avatar
You are supposed to seal them per tsp
Old Oct 12, 2009 | 03:55 PM
NegraRCSB2X4auto's Avatar
well I checked the compression on piston 7 and i got 170 piston 5 180 so I guess number seven didn't take a crap on me. But now i think that the oil is coming out of the exhaust running from piston number 7. all my plugs seem to have oil. Bad rings.....bad valve seals wtf. and my afr is reading lean *** hell when idling. I really don't want to pull the head off either.
Old Oct 13, 2009 | 12:31 AM
eallanboggs's Avatar
With compression numbers like that there isn't a whole lot getting past your rings. That doesn't leave much. Valve stem seals may be suspect if you're high mileage.
Old Oct 13, 2009 | 05:34 AM
bottom end has 25k or so. heads just got put on about year ago maybe 6k on them could the seals of gone bad that fast? I'm pulling it off today.......lets see what screwed up.
Old Oct 13, 2009 | 07:29 AM
turboescalade's Avatar
my engine builder told me the same thing, just put pipe sealant on your rocker bolts, torque them down and you should be good. he said its common for them to go into the runners
Old Oct 13, 2009 | 07:55 AM
You don't have to pull the heads to do the seals and rocker bolts.
Old Oct 20, 2009 | 09:51 AM
I know i don't have to pull the heads. I just wanted to make sure nothing on the block was damaged that i couldn't see. I never really found out where the oil was coming from. all I know is that i pulled the head put a new head gasket and new valve cover gasket. So if it kept leaking i knew to look else where. Now no oil leak and to ensure it was okay went to track this past sat. I ran my best time 7.4 in 1/8 which my goal was a 7.5 did the 7.4 smoking tires off the line. must of been the good air I'm happy no leak and my best time. So my bad week ended with a smile. thanks for the help guys.
