Just got my 4.10's and posi!!
Old May 30, 2004 | 02:44 PM
MGMC's Avatar
12 Second Club
Default Just got my 4.10's and posi!!
The truck feels alot better now. I just need to hit the track and see where I'm at as far a times. Traction is nice!!
Old May 30, 2004 | 04:03 PM
FILE's Avatar
I am glad you like it. How is your high end now. I am tempted to go 4.10 in the future.
Old May 30, 2004 | 05:47 PM
MGMC's Avatar
12 Second Club
My high end has kinda faded off, but the low end diffrence makes it worth it.
Old May 30, 2004 | 10:58 PM
DemonSilverado's Avatar
You did break them in first right?
Old May 30, 2004 | 11:04 PM
Hit Man X's Avatar
Kickass, the Eaton is a sweet LSD and can be upgraded with them heavier 800lbs preload springs.
I remember when I went from "peg-leg" w/ 3.55:1 gears to Eaton and 4.10:1s in my Ford, soooooo much nicer.
Old May 30, 2004 | 11:33 PM
FILE's Avatar
Eric, what is the stock preload strength and how will stronger springs benifit the lsd?
Old May 30, 2004 | 11:42 PM
Hit Man X's Avatar
File...
Stock springs are 400lbs of preload in the Eaton. Most real LSD's from the factory (Trac-Lok Ford and SureGrip Mopar) are like 100-200lbs tops.
Basically it puts more load on the clutches so they don't slip as much around corners. I'd do it only with a good amount power. It won't act like a spool by any means with the 800's in your truck, but it's gonna take more to get them to slip...so your rear is going to be locked most of the time...which I like. Just gots to be careful driving in the rain/wet streets...you can get turned around VERY easily. Looks cool but is pretty dangerous.
They were $70 or so when I ordered them. They won't go in my Ford until I have to rebuild the clutches in the Eaton.
kainzien
Nov 10, 2023 11:37 AM
turbo6c3
Oct 5, 2015 06:11 PM
Wolftrk99
Oct 2, 2015 08:17 AM
Cammed4ever
Sep 30, 2015 03:38 PM
lsxperformance
Sep 14, 2015 10:53 AM
