Just did a cam
Old Jun 21, 2013 | 12:49 PM
dmelvin's Avatar
Did you torque down the intake manifold bolts correctly? After I did my swap I missed one and the thing went nuts. Re-torqued everything and fired it up again and didn't have any problems.
Old Jun 22, 2013 | 09:43 AM
nikesb1111's Avatar
Took the thing back apart to check timing and this is what it looks like. The plugs are really black. I think I should rotate the cam gear a tooth
Old Jun 22, 2013 | 03:54 PM
nikesb1111's Avatar
I advanced it a tooth and it ran great for about 5 minutes then went back to running how it was. Anyone?
Old Jun 22, 2013 | 04:34 PM
oakley6575's Avatar
Yea it is definitely dumping fuel for some reason. Can you keep it running long enough to spray brake cleaner around the intake? If the engine RPM rises, there is a leak. It just sounds like an intake port needs to be capped.
The pics you tried to upload don't show up for me btw
Old Jun 22, 2013 | 07:28 PM
00sierra72's Avatar
Default Running problem
Hate to say but it may even be a bad tune causing all the issues!
Old Jun 23, 2013 | 11:07 AM
Mikey 97Z M6's Avatar
11 Second Club
Ok, so it sounds like you fixed the cam timing issue but now instead of dealing with two issues, now you're dealing with just one issue which is the MAF sensor code. Will it start and run good for 5 minutes when cold? You mentioned you cleaned the MAF, how did you clean it and what chemical, if any, did you use on it? Might seem silly, but is it installed the correct direction?
Mike
Old Jun 25, 2013 | 06:34 AM
nikesb1111's Avatar
It will barely even start at all now. When it does it will run for about a minute if you keep your foot on the gas. I cleaned maf with mad sensor cleaner and yes it's installed corrctlly
2500ZL1
Jan 25, 2016 06:30 AM
lawhitediamante
Aug 12, 2015 12:14 PM
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
