JP timing chain and melling pump update
Old Dec 25, 2014 | 11:43 AM
Go5.3tt06's Avatar
Default JP timing chain and melling pump update
I got timing chain JP5618 and melling oil pump #10296...
I need your help to correct me before I install with no mistake. I see the timing chain JP performance have a spocket with number for advance/retard timing. I thought we could stay a dot from cam to crank straight line up. Tell me how it work if it cant be same as stock the spocket i have now. I mean cam timing dot and crank spocket dot. I hope not confuse you?
Also the pump I saw the blue spring. The red one is in pump. Which is good for daily and boost turbo.
Old Dec 25, 2014 | 08:57 PM
Go5.3tt06's Avatar
is anyone know about JP timing chain. Id like to see your feedback before I can install myself? Many thanks.
Old Dec 26, 2014 | 10:35 AM
BlackGMC's Avatar
Resident Retard
I installed mine but i cant remember how i did it. I believe it came with instructions on how to line them up
Old Dec 26, 2014 | 02:42 PM
Go5.3tt06's Avatar
Originally Posted by BlackGMC
I installed mine but i cant remember how i did it. I believe it came with i structions on how to line them up
I'll pm you with the picture if it helps?
Old Dec 26, 2014 | 04:31 PM
BlackGMC's Avatar
Resident Retard
Did yours come with instructions?
Old Dec 26, 2014 | 06:26 PM
Go5.3tt06's Avatar
Just pm you
Old Dec 27, 2014 | 08:26 AM
Go5.3tt06's Avatar
I been research a lot about advance and retard. How about if I just leave it dot to dot without doing advance or retard? I plan to swap cam tu1 225 cam in. Will I able get some power from dot to dot. Let me know.
Old Dec 29, 2014 | 07:43 PM
Go5.3tt06's Avatar
I think it's ok to just stay dot to dot direct swap cam. I'm wait on Texas speed ship out some parts this week.
The melling pump which you use red or blue springs good for n/a and boost motor? I see ton of people like to with blue and some red one?
Old Feb 7, 2015 | 09:10 AM
Go5.3tt06's Avatar
Guys. Which would you suggest me run red or blue springs for MEL10296 melling oil pump
Old Feb 8, 2015 | 06:44 PM
99 2500's Avatar
I would leave the red spring since u mentioned turbo
5.3Okasai
Mar 9, 2022 01:07 PM
The_W
Oct 28, 2015 09:00 PM
chevyl33
Aug 24, 2015 08:21 AM
Ammadien
Jul 22, 2015 08:50 PM
Ferocity02
Jul 17, 2015 07:05 PM
