ive got this sick feeling that I screwed up bad
Old Apr 5, 2014 | 07:39 PM
  #21
TXsilverado's Avatar
no torque sequence, no valve lash adjustments. as long as you're running the correct length pushrod zip them down until it bottoms out and give it 22ft lbs. I like to turn the motor until the lifter is on the base circle of the cam, but it's not necessary.
Old Apr 5, 2014 | 08:21 PM
  #22
Jeebalow's Avatar
Here is the tightening sequence on the rockers. This is what I used on mine. You'd probably be ok not following it, but I like to be safe. Post # 34 in the following link or just scroll down to see the pic, should go right to it if you do click.
Corvette Forum - View Single Post - COMP Rocker Trunion Install
Edit- this has you tighten the rockers while they're on the base circle of the cam like mentioned above.
And because not eveyone likes to click on links:
Old Apr 6, 2014 | 12:33 PM
  #23
GMC93's Avatar
U sure you lined up the dots on the timing chain gears? I hear no compression...
Old Apr 6, 2014 | 04:38 PM
  #24
Bass Mechanic's Avatar
my guess is either you installed the wrong lifters and they are too tall or somehow you messed up reinstalling the valve train. because that engine is clearly turning over and has 0 compression.
Old Apr 6, 2014 | 07:32 PM
  #25
cosb's Avatar
Sounds like your push rods are too long, did you compare them to your old ones?
Old Apr 7, 2014 | 01:12 PM
  #26
Bartmon's Avatar
Originally Posted by cams 98 silverado
I did the exact same thing! On my 98 i tightened the rockers too much and the valves never closed so it never built compression. I knew exactly what you meant when I read your post then the video just brought back memories of me freaking out too. I would guess these rockers just tighten down right? dont have to do a sequence like the ol SBC's i thought?! Perhaps you over tightened them.
Correct me if im wrong, but ive seen many vids of people just torquing the rocker nuts down regardless of TDC or crank position. Guy did a cam swap and push rod swap and just tightened the rockers down to spec and buttoned up the engine.
You didnt break anything more than likely, just missing compression.
I tightened them down to spec according to the book and ended up bending 1/2 of my pushrods so I was real leery of cranking down on the rocker arms. Going to go home today and pull the valve covers.
Originally Posted by durty
on a non adjustable valvetrain you just torque the rockers to spec and be done with it
I did that when I was putting it back together and bent the pushrods when I tried to "horse" the engine over with my torque wrench on the crank nut.
the pushrods are the exact same length and the old ones. I'm going to find out today...I dont scare very easy but I'm a little nervous about cranking down on the rocker arms and ruin my cam.
thank you!
I never pulled the cam, I just swapped the lifters out.
the rocker arms are the only part of the valves that I've changed..the lifters are per chevy part numbers.
yeah they were exactly the same size. My hope is that the rocker arms arent tight enough because I didnt torque them to spec..but it seems like I should still have compression even if the rocker arms werent installed because the valves should be seated..
Old Apr 7, 2014 | 01:26 PM
  #27
Bartmon's Avatar
thanks everyone for your input, I def appreciate it. my hunting buddies are wagering that it wont run again...sorry basturds...
Old Apr 7, 2014 | 01:38 PM
  #28
where do you live?
Old Apr 7, 2014 | 01:56 PM
  #29
Bartmon's Avatar
where do you live?
in Austin near the y.
Old Apr 7, 2014 | 02:07 PM
  #30
Ferocity02's Avatar
You were bending pushrods when tightening down the rockers? Either your lifters are too tall or aren't installed all the way, or the pushrods are too long, or you forgot to install the rocker pedestal.
