I've been searching but I need specifics...
Old Jul 30, 2013 | 02:59 PM
Whitecrewcab's Avatar
To the OP, spend the money on a good set of headers designed to work with a catted midpipe. ARH or Kooks are the big ones that come to mind. I had to add cats to my off road Y and there is very little room between the collectors and the bends in the Y if its not designed together.
Old Jul 30, 2013 | 03:43 PM
DBLR1's Avatar
Registered User
Is your emmissions a sniffer or visual inspection, or just a plug into the OBDII port to check for any codes? If its just checkign for codes then you wont have an issue.
As far as bolt on mods go, the only one that will have a positive effect on mileage will be the tune. The mods you are talking about making will definitely increase air flow and power... but with an increase in airflow there is also an increase in fuel consumption. The truck does what it can to maintain a steady air fuel ratio, and with more air passing through it needs more fuel too.
That being said if it were mine and you just want a little more giddy up I would go with some stainless LT's and a single bolt on 3" cat back with the intake tube (your air box is actually pretty good) and a tune. If you want more than that go straight for boost.
A maggie makes for a great DD power adder. Throw 8# at it with the mods above and it would feel like a new animal... only thing I may change is a 3.5" cat back at that point.
It's the OBDII but they do look under the truck. I'm also not crazy about the tune to an extent. I don't want to void my warranty so I need to be able to remove it if I go to the dealer. I guess I'll have to go with a handheld so I can put it back to stock if necessary. That's kinda why I'm saying I want the cats, don't want to need the tune to delete the cats.
Old Jul 30, 2013 | 03:45 PM
DBLR1's Avatar
Registered User
Originally Posted by Whitecrewcab
Certain counties are noncompliance counties according to the EPA so they do emissions testing. El Paso is just a plug up to the computer and check for codes and status testing. Not sure how rough other parts of Texas get. Where I'm from, it's lights, brakes and forget just about everything else lol.
They basically do the normal stuff but they do plug into it looking for codes etc. If the check engine light is on it automatically fails...
Old Jul 30, 2013 | 03:46 PM
DBLR1's Avatar
Registered User
Thanks, I was thinking Kooks after reading the replies. It is probably my best bet overall. Rather be safe than sorry.
Old Jul 31, 2013 | 08:04 AM
Vortec350ss's Avatar
Quite honestly the mods wont be worth it if you wont have a tune to pull it all together. You wont get the most out of them, and its a lot of money to spend not to get as much as you can.
Honestly think about a Maggie. They offer a drivetrain warranty with their product. It won't effect drivability, but will add more power everywhere under the curve. Also, if you decide you want more down the road mods will make an even bigger difference. I.E. headers and a pulley swap could be good for over 50 HP at the same boost level.
Old Jul 31, 2013 | 09:01 AM
marineusmc4's Avatar
Originally Posted by RS/SS 4.8
Emissions testing? In texas? They just check to make sure your lights, horn and wiper work here in San Anto.
thats what they do here in kansas and missouri, thats why i was saying he would pass emissions with LTs and no cats (assuming he got that type of inspection)
Old Jul 31, 2013 | 10:14 AM
DBLR1's Avatar
Registered User
But if I get a tune or any other motor altering mod my factory warranty will be voided unless it can be removed prior to service. I'm down with a tune, as long as it's done right and can be easily removed. So I'm assuming a handheld would be my best bet, am I right? If I go with all my basic bolt on's, get a tune, and then once the 30K warranty is gone I can go for the maggie. That's kinda my plan but I'm not certain on which route to go with the tune.
Old Jul 31, 2013 | 10:16 AM
DBLR1's Avatar
Registered User
Oh and one more thing, I heard that the tranny that comes in these trucks is weak. Is that true? If so what's the best way to avoid issues?
Old Jul 31, 2013 | 11:49 AM
bobfig's Avatar
when i got my old truck inspected they just hook it up to read the computer never had a sniffer test on it. the was a 97 now that i have a 05 im not sure. they never really looked much at it. even put it as a v8 when it was a v6.
Old Jul 31, 2013 | 12:36 PM
In the past magnacharger has offered a separate powertrain warranty... might be worth looking into.
The tranny is just fine. The 6 speed is strong and you wont push its limits without some more serious mods.
Maybe I have a weird point of view... but IMO if youre looking for good performance in anything but the 'premium' engine there is no other answer than boost in a daily driven truck. I would think about headers, intake and tune on a 6.2 to run a mid 13 and call it quits... but otherwise I wouldnt waste my time. You will put all those bolt on mods on your truck only to possibly keep pace with a stock 6.2... give that thing a tune and its lights out.
That all changes when you're dealing with a single cab though.
Wolftrk99
Dec 3, 2015 08:12 PM
Chevy305
Sep 28, 2015 09:21 PM
sTNT971
Sep 26, 2015 06:27 AM
fortune46x
Sep 16, 2015 08:18 AM
pewter00
Sep 7, 2015 10:14 PM
