ironblock ls1
Old Aug 4, 2009 | 03:25 PM
454navyss's Avatar
Default ironblock ls1
here's the deal. my truck is starting to smoke a little on start up, probably the vavle guides leaking but with 159K in the truck im a little worried about the rings and bearings in the bottom end so im thinking about building another motor to drop in when mine goes.
what is the difference between a 5.3 bottom end and an ls1 bottom end? from what i can tell just the bore is different. if i bore a 5.3 block to a 5.7 with some slightly domed pistons (or should i go with a stock 5.7 piston?), 706 heads milled .030", tr224 cam, and full boltons what should i expect? is it worth the time and money to build a 5.7 or should i stay with a stock displacement? also, i will be keeping the stock intake if it matters.
Old Aug 4, 2009 | 03:36 PM
454navyss's Avatar
or should i build a 6.0 with the stock bottom end, same tr224 cam and milled 706s?
keep in mind this is still going to be my daily driver and i do drive quite a bit so i dont want to sacrafice too much gas mileage or get too radical, i will be towing with the truck as well as attending track days....i use my truck for everything
Old Aug 4, 2009 | 03:40 PM
00ChevyScott's Avatar
Wearin' da big hat
6.0 with worked 317s would be the best for the money imo
Old Aug 4, 2009 | 04:01 PM
454navyss's Avatar
what junk yard has the engines for like $85? im assuming 5.3s are easier to find than 6.0s out there?
i already have the heads, cam and pretty much everything to swap them to my engine, i just want a fresh bottom end too
Old Aug 5, 2009 | 06:00 PM
454navyss's Avatar
no other input?
Old Aug 5, 2009 | 07:19 PM
silveradokidd_4518's Avatar
i built an ironblock 5.7... machine work cost me 380 total... picked up a 4.8 for 300... but the crank i had to buy from a buddy and he sold that to me for about 75 and then the pistons i bought for 40 from a guy down the road from me...
Old Aug 5, 2009 | 07:22 PM
Wearin' da big hat
If you would've picked up a 5.3 you could've used the stock crank
Old Aug 5, 2009 | 10:03 PM
454navyss's Avatar
the 5.3 crank and rods are the same as an ls1, right? only the bore is different?
Old Aug 6, 2009 | 01:12 AM
StrokerAce03's Avatar
Yep; physically the same but a real LS1 crank has holes to lighten it I think......or something like that.
Old Aug 6, 2009 | 01:30 AM
Wearin' da big hat
I think the crank will need to be rebalanced for the LS1 pistons.
