Intake Manifolds?
it'll fit fiine....you need to swap the injectors, injector plugs and fuelrails off of an f-body to make it a really clean install, the only snag is the water-pump outlet...if you run a TB spacer it'll clear with the truck pump left on, otherwise you should probably run the f-body pump with the truck pump pulley
