intake for a 4.8 ?
Old Jan 23, 2007 | 05:03 PM
Red01chevy15004x4's Avatar
Question intake for a 4.8 ?
thinkin about putin a camaro intake on a 4.8 thats in a 2001 silverado. good idea or bad?
Old Jan 23, 2007 | 06:04 PM
2006 8.1's Avatar
I would be worried that that ports are bigger on the intake than the heads, and that you get some reversion at higher RPM. Also, 4.8 are not real torque monsters, but you might loose some torque because you will loose velocity through the runners, due to their larger size.
I would be almost inclined to put a larger throttle body on there and see if that would help. have you done any air box mods? You can also take the screen out of the mass airflow sensor for more air flow.
Good Luck
Old Jan 24, 2007 | 09:26 AM
moes04silverado's Avatar
Originally Posted by 2006 8.1
You can also take the screen out of the mass airflow sensor for more air flow. Good Luck
I would avoid this at all cost..I have heard nothing good about it, it wont give you any noticable gain...you would be better off buying a aftermarket one.
Old Jan 24, 2007 | 09:38 AM
ThunderZ28's Avatar
12 Second Club
it's been proven it doesnt help to remove it
Old Jan 24, 2007 | 10:12 AM
StrokerAce03's Avatar
I would avoid modifying the MAF any; including putting an aftermarket one on. The ls1 intake won't really give you any gains but an ls6 will yield better flow at higher rpms. Intake manifold swaps has been a hot topic for discussion lately. You should be able to find some good information by doing a search on this subject.
Old Jan 25, 2007 | 04:56 PM
2006 8.1's Avatar
I have taken the screens out of Mass Airflows on 5 different pickups and had zero issues at all. Never thrown one code, and after I hooked the battery back up and drove it awhile I liked the way it ran and sounded. Definitely worked for me.
Old Jan 25, 2007 | 07:34 PM
Phantom's Avatar
11 Second Club
descreen adds like .5 hp...i guess thats on a mustang dyno though..maybe .7hp
luis_bullz
Sep 8, 2015 03:08 AM
HectorM52
Aug 18, 2015 12:40 PM
03regcab sierra
20
Aug 3, 2015 12:11 AM
Castro45
24
Jul 31, 2015 07:13 PM
