Installing Walbro pump /with wiring questions
Old Jun 16, 2007 | 09:22 PM
Default Installing Walbro pump /with wiring questions
I have the bed off and the sending unit and pump out already. I know which wire goes were to hook up the new pump. But should I solder the wires together and then use shrink tubing on top of the wire splice? I remember reading on here(and yes I did a search) but couldn't find were that one of the guys used shrink tubing and the gas ate it up. If that does happen does it make those exposed wires a fire hazzard? I just am a little concerned about burnin my truck to the ground after doing all this work to it.
Any help will be a great help THANKS.........
Danny
Old Jun 16, 2007 | 10:55 PM
DrX's Avatar
DrX
You could use Teflon(PTFE) heat shrink and offset the 2 splices so that if they were exposed, they couldn't contact each other.
Old Jun 17, 2007 | 10:46 AM
So will the gas and electricity thing be an issue if the spliced wires become exposed or is it only a issue if the two splices touch each other?
Old Jun 19, 2007 | 09:29 AM
ttt ttt
Old Jun 19, 2007 | 09:47 AM
DrX's Avatar
DrX
There is already "exposed" wiring at the connectors. You just don't want anything shorting out or any loose connections. Also, make sure everything is grounded as it was in the factory setup. For example, there was a ground to the metal FPR in my stock module. Should be OK with the proper heat shrink and wiring.
thunder550
Oct 8, 2015 04:53 PM
1slwgto
Aug 16, 2015 06:40 PM
Ammadien
Jul 22, 2015 08:50 PM
lxcoupe
Jul 21, 2015 02:12 AM
Mossyoakglock
Jul 17, 2015 08:30 AM
