Installed My cam Same power
Old Oct 21, 2008 | 01:45 PM
Denali Dude's Avatar
Default Installed My cam Same power
I installed my cam today tuned the car but I have the same power as before Is it because of the headers (Stock) We couldnt give it more timing because Of my stock exhaust Just a Cutout
Old Oct 21, 2008 | 05:46 PM
sickREDsierra's Avatar
its really hard to feel 20-25 hp in a big heavy truck.
on a dyno, you probably picked that up at least, if your tune is on, but again, just very hard to feel that small gain in a 5500 lb beast.
Old Oct 21, 2008 | 06:40 PM
white1's Avatar
A real dyno, or a butt dyno showed no gain? What cam did you install?
Edit I see a cam in your sig is this it? Im asking cause the thread says you tuned the car, but you sig list a truck. Not being a smart ***, just asking. If you installed the cam in your sig, you should have seen a gain over stock
Old Oct 22, 2008 | 02:42 PM
Yes I haqve installed the cam before 2 days tuned it but still having problems because no headers and yes thats my cam in the signature.
Will I feel more power out of the cam If I installed headers? And everytime I start my car the check engine comes out if the engine was little cold and its a misfire code
Old Oct 22, 2008 | 02:54 PM
GMCtrk's Avatar
Check all your spark plugs and wires.
Old Oct 22, 2008 | 03:08 PM
Checked them Its a knock retard
Old Oct 22, 2008 | 03:19 PM
krambo's Avatar
P0300 Random misfire code??? It is common to have that code after a cam swap. If you are tuning, bump up the "hit count" for the misfires, dial in your fueling and more than likely, you can increase timing a tad. You should see a nice difference.
Old Oct 22, 2008 | 05:26 PM
I can increase timing a little but I dont have headers maybe I will have a detonation or something
Old Feb 6, 2009 | 11:53 PM
norris_83's Avatar
dude who did ur tuning?? come to kuwait
Old Feb 7, 2009 | 12:02 AM
viciousknid's Avatar
Where's the Beef?
Did you have a tune before the cam? You should have felt a HUGE difference in that sled from a tune ALONE.
That cam should have definitely felt faster on the Butt dyno. My 216/220 did.
