instaling eaton??
Old Jan 1, 2003 | 02:27 PM
BigTex's Avatar
Default Re: instaling eaton??
Post this up in the drivline section. I'm sure you'll get a better response from those guys. Sorry I can't help.
Old Jan 2, 2003 | 12:43 AM
parish8's Avatar
single digit dreamer
Default instaling eaton??
woo hoo, went out to get the paper and there was an eaton siting on my porch. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> got a couple of quesitions on the install.
what do i torque the caps to? what about the ring bolts? do i need to use any locktite on any of those bolts? can i tap the new bearings on or do they need to be presed on? the shim kit came with 2 thick but smaller diameter shims, what are they for?
what should the clearance/lash be between the gears and since i am not touching the pinion, once i have the lash set shouldn't the pattern be good?
guess thats more than a couple of questions, thanks in advance
LCHEE
Oct 24, 2020 04:10 PM
Turk55
Sep 11, 2015 11:52 AM
zblee
Aug 3, 2015 03:45 AM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
