Injectors Issue
Old Feb 24, 2011 | 01:25 PM
Denali08's Avatar
Default Injectors Issue
I ordered Fast Injectors PN 30507-8 ton install it in my truck because it's lean with stock L92 truck injectors. The Fast Injectors turned out shorter that the stock L92 although they are labeled by Fast as L92, L76, LS7. Harness plugs are fine beacuse I already changed to EV6 harness plugs.
I have done L92 heads/L92 truck intake swap.
So, which injectors will fit L92 trucks? Are they same as LS2? Or does L92 need special order injectors?
See attached picture that also made me convinced to order those fast injectors!
Is there a spacer to fit those fast injectors. They look a little smaller at fuel rail side compared to stock L92 injectors. I hope they don't leak if fitted using spacer.
adunphy
Feb 22, 2016 06:38 PM
05GMC4.8
Aug 7, 2015 09:55 PM
GMCtrk
Jul 17, 2015 06:39 PM
jrplz
Jul 9, 2015 12:07 AM
