Injectors? 57lb,60lb?
Old Feb 3, 2006 | 08:09 PM
03sierraslt's Avatar
Default Injectors? 57lb,60lb?
Ok here is the dilema, from what I can tell I believe that I may be maxing out my injectors. Hptuners was showing a 103% duty cycle at WO, I am assuming this means its time to go bigger? What is everyones input on this? I am kinda suprised I am maxing them already, this was at around 8.5-9lbs. I plan on raising the boost some once I get this intercooler project figured out and done so I am trying to plan ahead here. Tips, opinions, anything.........
Old Feb 3, 2006 | 08:11 PM
How much of a PITA is it going to be to tune it to have good driveability? I know CHarris did I believe 60lb injectors, anyone else?
Old Feb 3, 2006 | 08:45 PM
quicksilverado's Avatar
60s are much easier to tune.
Old Feb 3, 2006 | 09:33 PM
You mean that the 60s are much easier to tune then the 57's?
Old Feb 4, 2006 | 07:42 PM
Anyone????
Old Feb 4, 2006 | 07:59 PM
You got it.
Old Feb 4, 2006 | 08:23 PM
AintNoHo's Avatar
Since you're continuing improvements, get the new injectors. Bigger is better and doesn't really bother idle and low speed unless you said you wanted 180 pounders. I assume you're going from 44lb to 60lb. Shouldn't be a problem with programming.
Old Feb 5, 2006 | 11:26 AM
Yes 44lb to 60lb is what I am thinking.
$A_Money$81
Mar 27, 2023 10:25 AM
shootermwc
Oct 8, 2015 01:45 PM
KleanKustoms
Sep 30, 2015 05:07 PM
Wrecker 426
Sep 29, 2015 11:00 PM
sTNT971
Sep 26, 2015 04:22 PM
