injectors???
the largest injector you can just bolt/plug in seems to be a 42lb/hr(@58psi), you can get that at http://www.rceng.com/technical.htm , they are expensive!!
injectors for the ls1 motors are a little taller and have a diferent conector but you can make them work, i got a set of 50's from racetronics, people say these big injectors are hard to tune and don't idle well. i havn't had ANY problems, it idles smooth and took about an hour to tune them in with ls1edit.
here is a nice article about injectors, lots of good info about why you don't want to cut it too close on size with injectors, also sugests the best types of injectors. http://www.supras.com/~riemer/sonict...rs/RCtech.html
what is your planed set up, a 50lb injestor is prety big.
I also have a question on this as well? I recently bought a 5.7 ls1 and all i have are the 5.3 injectors. The motor i bought was dynoed @ 385 rwhp. Will the 5.3 injectors hold this? <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> If not then what size should I install? I believe the 5.3 are around 21-24 lbs/hour. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> thanx.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by GoldenVelvet:
<strong> Hey parish;
you seem to spend a lot of time on the Supra page. Do you own one?? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">nope, i don't spend any time there, thats just where that page came from, that is some of the best injector info i have ever seen on that page.
shootermwc
Oct 8, 2015 01:45 PM
