injectors
Old May 13, 2005 | 09:53 PM
Fogle07's Avatar
Default injectors
a buddy of mine has a f150 with a kenne bell supercharger on it and hes putting some bigger injectors in it to handle the boost and i was wondering if the injectors that came in the kenne bell kit (36lb.) would work in my 00 gmc sierra with a 5.3? also are those larger than my stock ones? TIA
Old May 13, 2005 | 09:58 PM
They would fit if you changed the injector plugs and space the fuel rails.You would also rescale the pcm for bigger injectors.
Old May 13, 2005 | 10:04 PM
Fogle07's Avatar
the ones out of his have two connectors on the injector. how many does the ones on my truck have?
Old May 13, 2005 | 10:25 PM
2 wires with 1 plug on each injector.You could splice your wires to make them work if the plugs come with the injectors.If not,you'd best price those plugs before buying his injectors.
$A_Money$81
Mar 27, 2023 10:25 AM
shootermwc
Oct 8, 2015 01:45 PM
KleanKustoms
Sep 30, 2015 05:07 PM
Wrecker 426
Sep 29, 2015 11:00 PM
sTNT971
Sep 26, 2015 04:22 PM
