Injector swapping questions
Old Jan 24, 2008 | 07:21 AM
tdrumm's Avatar
Default Injector swapping questions
For those who have swapped out their stock injectors for another set that are plug and play, how long did it take you, how hard was it to do, and what tools did you need?
I am planning an injector upgrade, but I don't want to change them out at home, and then drive 2 + hours to my tuner to get retuned. I'd like to know if I can swap them out in his parking lot, of if that is too much trouble.
Thanks.
Old Jan 24, 2008 | 07:47 AM
truckmann's Avatar
I think that should be easy enough. It's not real tough, I think I took about an hour to do it. Could be done faster if you hurry. Just a couple of basic hand tools needed unless you want to take the fuel rail off then you would need the special tool to disconnect the fuel line, but it isn't necessary to disconnect the fuel line.
Old Jan 24, 2008 | 08:35 AM
dewmanshu's Avatar
Moderately Differentiated
you'd need to tell the pcm the inj rate. I guess it'd be "okay" for a ride to your tuner if it ran, it would be dog rich. Bigger orifice opening and closing at the smaller inj rates.
Old Jan 24, 2008 | 09:04 AM
tdrumm's Avatar
Well, that is the thing, I don't want to change them out at home and then drive to the tuner pig rich and risk washing the cylinders with gas. That is why I was thinking about changing them out at his shop. Or if it's as simple as changing a value in the tune from 24.7 #/hr. to 42#/hr, then I guess it could be done mail order and everything could be done in my driveway.
Old Jan 24, 2008 | 09:51 AM
dewmanshu's Avatar
yeah tdrumm I agree...how about this for an asnwer, If it was me doing it, I'd make sure the pcm knew the new injector size before firing it up.
Old Jan 24, 2008 | 09:56 AM
If you get a set of 42# Multec injectors from Thunder Racing it's just as simple removing the fuel rails and replacing the injectors with the new ones. The Multec's are physically identical to the truck injector. Just bleed the pressure off of the fuel rails, remove the wiring and old injectors, lubricate the o-rings on the new injectors so they install easily in the bores and reconnect everything. It only takes about 30 minutes at the most and you ony need a few metric tool's like an 8 mm and 10 mm, that's really it, you don't even have to remove the fuel lines. If your halfway mechanically inclined you'll have no problem.
Old Jan 24, 2008 | 02:35 PM
Tootall's Avatar
they're planted in there . . . like they grew roots and you're yanking them out with the injector.
If it was me, I would swap them there at your tuner, but bring tools to pull them. Get a large set of electrical pliers or some channel locks, a fuel line disconnect tool, and a ratchet for taking off the fuel rail.
Old Jan 24, 2008 | 08:03 PM
budhayes3's Avatar
PT's Slowest Truck
I can't remember what tools I used, but when I swapped my 19 lb injectors out for 24lber's, I did it in under an hour (that was a couple years ago). If you had 2 sets of hands working on it, it would be even quicker
Old Jan 24, 2008 | 08:12 PM
ridnlow's Avatar
As others have said its a fairly easy process.. My brother and I did mine in about 20 minutes.. The only thing that took a while was getting the old o-rings off..
Old Jan 24, 2008 | 09:11 PM
budhayes3's Avatar
PT's Slowest Truck
Yeeesss, as I remember, that was the hardest part
