injector swapping advice please
going to 44 lb injectors tomorrow..
where/how should i bleed the pressure off the fuel rails?
any specialty tools needed? gonna do this in my tuners shop, right before he tunes it.. just trying to get these ducks in a row.
thanks.
thanks.
I just bleed pressure at the schrader valve. Put a rag under it and either unscrew the valve or just press the valve.
You may need to unhook the fuel lines from the rail. A special tool is needed to do that.
my tuner said the 07's are held in with an o-ring instead of a clip on the rail?
he said you just pull em out with channel locks.. sounded fonky, but i dont know, i have never fonked with em.
i will but the tool just incase. i assume i can get it at autozone or o'reilly ?
ARC
57
Feb 21, 2022 10:54 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
Nimoryan
Jul 5, 2015 03:50 PM
