injector swap ?'s
Old Nov 18, 2005 | 03:23 PM
TwoFast's Avatar
Default injector swap ?'s
When swapping out the injectors for my supercharger install, I was told that I can use a little bit of trans fluid to lube the o rings on the injectors, so they slide right in. Can I do this, the install instructions for the blower say to use lithium grease, but basically you want something just to make the o-rings slide in and seal properly, correct?
Thanks
Old Nov 18, 2005 | 04:17 PM
Mort's Avatar
Cool
I used dielectric grease on mine. I am not sure if the trans fluid will damage the o-rings or not. May as well just buy a small tube of lithium grease and sleep good at night.
Old Nov 18, 2005 | 08:50 PM
kbracing96's Avatar
Any kind of oil/lube will work, those o-rings are made out of some tough stuff to stand up to fuel.
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
OHsixLS3
Dec 27, 2016 09:30 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
jrplz
Jul 9, 2015 12:07 AM
Deceptarado
Jul 8, 2015 05:24 PM
