injector size Q
Old Sep 24, 2006 | 09:30 AM
bluecajun5.3's Avatar
11 Second Truck Club
Default injector size Q
what size fuel injectors does my truck have?
i did a search, does 24.7# sound about right?
i just wanted to make sure.
thanks,
lance
Old Sep 24, 2006 | 09:35 AM
v8
17,16,15,14,13,12,11 Drvr
probley unless you have the flex fuel, if you open your gas tank door there will be a sign that says don't run additives with E-85 if so then you have the flex fuel injectors. if not then you have the 24lbs ones.
Old Sep 24, 2006 | 09:38 AM
dont the 1999/2000 models only have 22#?
Old Sep 24, 2006 | 02:33 PM
ok.
then they should be the 24# b/c my truck is an 03 (non flex fuel)
Old Sep 24, 2006 | 02:34 PM
i think so. maybe even 21 i read while doing a search.
Old Sep 24, 2006 | 09:35 PM
...that would explain my 100%IDC at 6400 with my mods haha
Old Sep 25, 2006 | 04:05 AM
hell i'm at 104% but still not going lean.
Old Sep 25, 2006 | 07:26 AM
yea im not lean yet either and im tuned rich until i get the wideband but its all good, sorry for the
Old Sep 25, 2006 | 08:34 PM
budhayes3's Avatar
PT's Slowest Truck
I *think* only the 99's were lucky enough to have the smaller injectors...21lbs seems to jump into my head for some reason. Although 99/00 both had the PCM/KR issues.
24.7lb seems to be the number that I've seen for all other (4.8 5.3 6.0)injectors though....and 31lb for 8.1 fuel injectors, and 42ish for 8.1 marine injectors.
Old Sep 25, 2006 | 08:38 PM
v8
99 had the 19lbs injectors the 00-0? have the 24lbs, the newer ones that have flex fuel run 38lbs injectors.
Stainless Works
13
Nov 5, 2015 03:31 PM
WICK3DxGATA
Aug 31, 2015 07:21 AM
maxspeed05V
Aug 12, 2015 06:29 PM
FlowmasterMufflers
Jul 30, 2015 05:03 PM
jrplz
Jul 9, 2015 12:07 AM
