Injector question
I'm not sure on what injectors I have but most likely they're stock. Well my question is with my mods in sig should I go with bigger injectors or not? If so what size? Thanks in advance.
i would say run a set of flex fuel injectors in it. im running 57lb/hr but i have 11.5:1 compression and a set of stage 2.5 heads. but other than that i have almost the same mods. but if you have stock injectors you will be at i think 26lb/hr and flex fuels are 36lb/hr injectors. you will still have alot of room to add to your truck.
if you go 36's you can turn down the duty cycle to fit your needs. i would recommend the 36's. they are cheap. but if you decide on a set of 30's and you feel they will fit your needs for a long time i have a set sitting in my tool box i never used. i think they had like 40K on them. ill send them to you for 15 bucks. that should more than cover shipping.
on a side note how much power are you getting at the flywheel? about 380?
5.3lSilverado
25
Aug 29, 2016 12:48 AM
bbowerman
Jul 26, 2015 10:57 PM
