injector question 5.3 to 6.0
Old Aug 29, 2006 | 12:19 AM
Tahoe6.0's Avatar
Default injector question 5.3 to 6.0
just installed 03 lq4 6.o in 02 tahoe.the intake was swapped with cable tbi, the 6.o fuel rails and injectors were installed, then the injector connectors are differant on the 6.0. so I installed fuel rails and injectors from 5.3. are the flow rates differant on the 5.3 ones compared to the 6.o injectors. the rails also look fatter on the 6.o engine. I,m getting a nelson tune this week for the engine. Should I buy diffrant injectors? I thought they were supposed to be the same? any help would be greatly appreciated. The swap was going smooth except the bell housing bolts / stud access. now the injectors might be a problem.
Old Aug 29, 2006 | 12:53 PM
kbracing96's Avatar
The injector will be the same from a 5.3 to a 6.0 (24lbs/hr), unless one of motors is flex fuel, which it sounds like the 6.0 might be. They have larger injector (33lbs/hr) to accommodate the higher fuel needs of E85 and different plugs on them. You should be fine with the 5.3 injectors on your new 6.0.
Old Aug 29, 2006 | 03:35 PM
Tahoe6.0's Avatar
I checked the gm part numbers and the 6.0 hd has differant fuel rails and injectors for some reason! The engine I have is (hd 6.0) still dont know whats the diff. Maybe some one knows and could post it for me. maybe I should change to the hd injectors and change injector ends wiring? Thanks
ferrellrooster
Mar 6, 2025 03:22 PM
OLD BULL
Aug 1, 2015 05:00 PM
steves86ta
Jul 28, 2015 10:21 AM
vmaxpro
Jul 27, 2015 10:45 PM
justuc
Jul 24, 2015 11:52 PM
