injector connector help
Old Apr 18, 2003 | 04:30 PM
sleepersilverado's Avatar
Default injector connector help
some one piont me in a direction were i can get a set of f-body injector conectors. i did post it in the want section about a week or two ago but had no hits. the dealer wanted 17something a piece that would total like around 160$ for all of them. <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
so some help would be apreciated.
Thanks Ryan
Old Apr 18, 2003 | 07:20 PM
L-EATER's Avatar
11 Second Truck Club
Default Re: injector connector help
Lots of vehicles use the same injector connector. Lt1's, Mustangs, 3800 V6's etc. You might be able to go to a salvage yard and hack some off an old harness. I am needing to upgrade my injectors and can't decide if I want to spend the $$ for the ones that go right in or hack some connectors and go with the ford injectors.
Old Apr 18, 2003 | 09:04 PM
BigTex's Avatar
I paid Valvegod (Shaun Carter) $50 for what he called a pair of sub-harnesses. I felt like it was too expensive, but I already had the SVO injectors, so I needed it. I sold mine to Parish8 when I pulled the whipple off. I just cut the Bosch wire conectors off, cut my truck injectors off and spliced them in. It was no big deal. There is a common colored wire that is the ground I assume, just keep them matched up. Then you will need to add 3/4 longer bolts to the fuel rail and a 3/4" spacer to make up for the longer injector. It will take a little bending to get the crossover tube to fit properly. I had a few issues with leaking gas fron the fuel return line due to the improper height of the rails, but I fixed it. Also, you will have to slightly elongate the fuel rail hole as it will shift a little with the longer injectors.
Truck injectors on the right, LS1 injectors on the right:
<img src="http://www.z71.net/inj3.jpg" alt=" - " />
Old Apr 19, 2003 | 01:37 AM
thanks i will try a junk yard.
OHsixLS3
Sep 25, 2015 11:20 AM
kalikid06
Sep 20, 2015 07:46 PM
jroctpb
Sep 16, 2015 09:05 PM
lxcoupe
Sep 2, 2015 12:58 AM
