Info On Multec 2 42lb Injectors???
Old Oct 8, 2004 | 02:19 PM
jnybbad's Avatar
Default Info On Multec 2 42lb Injectors???
I have a 2002 Silverado with the 6.0l motor. I also have an STS turbo system on it. I am going to install the Multec 2 42 lb injectors but I have one question. I have read a lot of previous threads and on-line info about how to pick injectors. The multec 2 42 lb injectors are rated at 42 lbs @ 58 PSI fuel pressure. This puts them at about 37 lb injectors at 43.5 PSI which I was told is a standard for fuel injector rating. Do I have Nelson performance set my PCM for 37 lb injectors or for 42 lb injectors?? I was also told that the fuel pressure will rise as the boost rises. So with 6 PSI boost I will have 64 lb fuel pressure.
What is the best info I need to give Nelson to be in the ballpark so it will run to get it scanned.
Old Oct 8, 2004 | 02:31 PM
Black Blown 02's Avatar
Have nelson set it for 42 lb'ers. Fuel pressure only rises until 0 vacuum. It goes from 52 at idle to 58 at 0 vac.
Just tell nelson you have an STS with 42 lb'ers, and whether or not you're running an intercooler or alky injection.
Old Oct 8, 2004 | 03:07 PM
jnybbad's Avatar
OK thanks for the help!!
Old Oct 8, 2004 | 03:09 PM
Chevmann99's Avatar
I just bought these from Arizona Speed and Marine, they are refered to as 43lb injectors on the site, I called them and asked and they said they are the stock 8.1L GM injectors. I have heard them refered to as 42lb injectors on many occasions here. So what are they? I am getting my PCM flashed next week, is the difference in 1lb gonna matter when they do the tune? Sorry don't mean to hijack your thread.
Old Oct 8, 2004 | 03:24 PM
zippy's Avatar
you shouldn't need the FMU with the larger injectors.
Old Oct 8, 2004 | 03:25 PM
jnybbad's Avatar
Me again. I spoke to Nelson and they told me that I can go ahead and install the new 43lb injectors with the tune that they sent me. The tune was for 36lb injectors @ 43.5 PSI. They said it should run good enough to get a scan and then he'll fine tune it for me.
Any thoughts? I just dont want to install the injectors and then it will not run correctly.
Thanks for the input.
Old Oct 8, 2004 | 03:26 PM
HEY wait a minuet, thought stock 8.1s had like 30lbs while the 8.1 marine injecters for 42 lbs....or did i smoke crack somewhere.
Old Oct 8, 2004 | 03:36 PM
F8L Z71's Avatar
You are correct....
Under boost my fuel pressure will rise to just over 60psi but I am already running out of injector with the 43lb units so just a heads up if any of you turbo/blower guys plan on running 12psi+.
Old Oct 8, 2004 | 03:51 PM
Chevmann99's Avatar
Yes they are they are the marine injectors.
adunphy
Feb 22, 2016 06:38 PM
jtphelps289
Sep 1, 2015 08:58 PM
Sexyrado327
Aug 2, 2015 04:08 PM
gtyler04
Jul 28, 2015 06:21 PM
