Impressions Of The Comp 212/218 114lsa Cam
Old Jul 3, 2004 | 11:09 AM
TigerFan187's Avatar
Im lucky enough to be able to ride/drive his truck with the new cam and Im sure after I get a chance to it will be the one I get!!!!! We will see what it can really do after i get my gears and get you out to thw track in a few weekends!!!!!
Old Jul 3, 2004 | 11:36 AM
Sport Side's Avatar
Originally Posted by dowright82
I know a little about cams, but why the reverse split, how does that benefit?? I thought that was only when you were using a very restrictive exhaust or something . . .
no, perhaps your confused on what a reverse split is. Its where the intake duration is larger than the exhaust duration. For example, comps 212/218 is not a reverse split, it is a regular split cam.
if you have a restrictive exhaust a regular split may be better suited for your needs. a reverse split cam is to crutch a poor flowing intake and equalize exhaust and intake flow. This is because the intake is the LS1's restriction. reverse splits are great with cut outs or open headers also.
so if you have headers, you will probably see no gain in a higher exhaust duration and lower intake duration. an increase in the intake duration will hold the intake valve open longer, bringing in a larger charge and creating more power.
but, then you get into, how much intake duration is to much and overlap.
for ex. you heard people telling 01 thunder, that the TR224 may be to big for his 4.8L. I saw a good example of this in the internal section. Holding a cup under the faucette and filling it up. Once the water reaches the top it doesn't keep on filling. It spills over the sides. So in other words, holding the valves open to long, may be overkill. Killing low end tq.
Old Jul 3, 2004 | 12:51 PM
14 Second Truck Club
Originally Posted by TigerFan187
IWe will see what it can really do after i get my gears and get you out to thw track in a few weekends!!!!!
Me too. After I get my gears, Blake's gonna need more than 3.73's w/ 26" tires, 2200 stall, and "Blake Carter Slow Trucks" Dyno-Tuning!!!
Me CARAZYCUTER4.8
Old Jul 6, 2004 | 08:38 AM
CARAZYCUTER 4.8's Avatar
Originally Posted by rcfast
do you have any sound clips?
I HAVE A FEW VIDEO CLIPS THAT I INTEND TO POST IN THE NEXT COUPLE OF DAYS. THE CAM SOUNDS SWEET! I RAMPED UP THE TIMING THIS WEEKEND TO 29 DEGREES AND RAN 93 OCTANE IN DALLAS WITH THE TEMP AT 95 DEGREES OUTSIDE AND RECORDED NO KNOCK AT ALL. THE CAM LOVES TIMING & PROVIDES A BROAD TORQUE CURVE.
Old Jul 6, 2004 | 08:45 AM
Me CARAZYCUTER4.8
RICHARD DONT BE KNOCKING MY SLOW TRUCKS BYBLAKE CARTER TUNE! YOUKNOW I AM THE BOMB
Old Jul 6, 2004 | 09:27 AM
racer88's Avatar
I have that cam in my car w/ a higher lift I believe .563 .582 and my car ran 11.91 @ 116 on a drag radial with exhaust and gears full weight. Great cam, can't even tell theres one in my car.....stealthy and lethal to unsuspecting cars that challenge me on the street
Old Jul 6, 2004 | 12:58 PM
12sec.5.3's Avatar
I am running that cam also. I like it but really thinking about trying the comp 216/220.
Old Jul 6, 2004 | 01:23 PM
Next month when I go to the track, I'm still gonna kick your ***!
J/K
Old Jul 6, 2004 | 02:56 PM
Sport Side's Avatar
Originally Posted by 12sec.5.3
99 Silverado Reg. cab 5.3
K & N Gen II, UD Pulley, Comp Cam .212/.218 .521/.528 w/918's, FMS pushrods, ASM headers, 3'' true dual QuickFlows, Mild head work, 2800 vigilante, vette servo, 3.90's w/ eaton, LS1 Edit, Flexalite fans, Ported TB, 160 T.Stat
12.81 @ 103.59 - 1.72 60'
quickest n/a 325ci right there. nice time
Old Jul 6, 2004 | 04:09 PM
02Reaper's Avatar
Yeah, I thought so too. I've asked him a few questions from time to time and he seems to be a pretty nice fellow. Maybe he will chime back in and let us in on some of his secrets .
