Im gonna order this cam...
Old Aug 2, 2006 | 04:10 PM
Default Im gonna order this cam...
Comp 224/224 .581/.581 112lsa
what else should I get, summit links would help out. like rods and springs?
Old Aug 2, 2006 | 04:17 PM
goshawk23's Avatar
Truck addict
no links to summit please. they aren't a sponsor.
i would get some comp 918 springs and rod bolts are nice to have for added strength and insurance
check out our sponsors. they have everything you need...
Old Aug 2, 2006 | 05:56 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
I wouldnt bother with rod bolts you will need to pull the motor to put them in since you are 4wd. Trust me you dont want to pull the front diff and all that stuff, ask me how I know
You better get a 3600 stall since you have the little motor and 4wd to spin. Too much cam IMO for what you got. You dont even have a tune, lt headers if I remember correctly. You gotta walk before you can run but do what you must.
Old Aug 2, 2006 | 07:12 PM
Cuerva's Avatar
11 Second Truck Club
some comp 918's and hardened pushrods should do it.
Old Aug 2, 2006 | 07:37 PM
.T.'s Avatar
.T.
what else should I get, like rods and springs?
That's alot of cam for a 4.8. You're going to need serious tuning to run it. Then, you're gonna want at least a 3000 stall. And, with that much lift, you'll need 918 springs and 7.4 pushrods. You might even run out of fuel and need bigger injectors to feed that at high RPM.
Have you considered calling Don at Dez's shop about setting up your tune?
Old Aug 3, 2006 | 05:05 PM
1slow01Z71's Avatar
He needs atleast a 3500 for it to run well. 01Thunder is running a 3500 and it hits pretty good but he is a step side and 2wd big difference.
Old Aug 3, 2006 | 05:24 PM
RoosterMcCandles's Avatar
What are your current mods?
Old Aug 3, 2006 | 06:09 PM
Derek @ EDO's Avatar
FormerVendor
go smaller for a 4.8
Old Aug 3, 2006 | 07:10 PM
TravisH's Avatar
I thought he bought a 6.0???
Old Aug 3, 2006 | 07:24 PM
Tan327's Avatar
Yeah, I think he's got a 6.0 now. I'd buy cam, springs, and pushrods.
