ignition timing with a radix
Old Dec 5, 2004 | 12:41 PM
hdhorsepower's Avatar
Default ignition timing with a radix
just installed my radix with a westers tuned computer for the radixand when you get on it it pulls the ignition timing back to around 8-11 degrees.i hear no audible detonation it has 93 octane gas in it anyone have any ideas? thanks it is an all new setup the computer and the radix.
Old Dec 5, 2004 | 12:43 PM
Flyer's Avatar
What size pulley? Or how much boost?
Old Dec 5, 2004 | 12:47 PM
it came with the 3.1 pulley and boost i dont no i dont have a gauge on it yet but it will pull the timing out of it while it is sitting in the garage when you hit the gas pedal it will go from 17 degrres and drop down to 2 or 3 degrees .
Old Dec 5, 2004 | 12:55 PM
Flyer's Avatar
Get some figures on it cruising down the road. How are you getting the timing numbers anyways?
Timing wiht no load doesn't really tell you anything.
Old Dec 5, 2004 | 01:03 PM
driving down the road it runs about 26 degrees when you jump on it it immiedatly drops to 8-10 degrees
Old Dec 5, 2004 | 01:12 PM
Flyer's Avatar
The stock SuperChips tune puts about 17* at WOT up top. It can take considerably more than that though. I'm running a couple more pounds of boost and a bit ore timing than that. A little timing on a blown motor goes a LONG ways.
Old Dec 5, 2004 | 01:25 PM
i guess i will have to get a hold of westers and see what they have to say but thanks for the help flyer. do you have your tb coolant passage hooked up cause i left mine bypassed and when you take the 2 wires off of the maf harness to wire the new iat sensor do you still hook the rest of the wires up to the maf sensor or do you leave them unplugged? cause when i left them unplugged the set a low voltage code on the maf circuit but it doesnt change how it runs. thanks
Old Dec 5, 2004 | 04:27 PM
KySilverado's Avatar
I'm with Flyer on this. Mine with unmolested timing from the Magnacharger/SuperChips tune, scans at 17* on WOT pulls. Some being pulled at shifts. Plan on pumping this up once I get my fueling straightened out. New to tuning and HP Tuners.
Flyer how much you got going?
Old Dec 5, 2004 | 09:36 PM
Flyer's Avatar
Before I put the 5.3 heads on I had as much as 23* timing up top. That was on a 60-70* day. That may change if the weather gets hot or after repeated pulls.
hd, plug the MAF back up. It still needs the readings.
Jakejack
Jan 8, 2024 10:44 PM
ss4chad
Aug 15, 2015 02:25 AM
therock
Jul 25, 2015 09:23 AM
atxlt
Jul 20, 2015 11:06 PM
sTNT971
Jul 16, 2015 12:39 PM
