if you are thinking about a 6.0 swap look here
Old Oct 30, 2005 | 01:39 PM
parish8's Avatar
single digit dreamer
Default if you are thinking about a 6.0 swap look here
This is important. Several people have made this mistake.
When looking for a used 6.0 motor it needs to come out of a 2001 or newer truck. It will have aluminum heads on it and the crank flange should be flush with the seal. If the flange sticks out past the seal you will not be able to mate the motor up to the tranny. People have tried and were not able to get it to work.
here is a picture of the proper crank flange.
Old Oct 30, 2005 | 01:47 PM
YenkoST's Avatar
Good info!! I knew about the heads though but not the seal!
Old Oct 30, 2005 | 05:02 PM
CHarris's Avatar
That's a good thing to share. Lot's of people wouldn't know about that issue. I know I didn't!
Old Oct 30, 2005 | 05:05 PM
FILE's Avatar
Thanks for sharing.
Old Oct 30, 2005 | 05:45 PM
RangerTJ's Avatar
Just a few months and one transmission too late for me, but good post.
Will
Old Oct 30, 2005 | 06:31 PM
99Silver6.0's Avatar
Thats a good pic to post!!
Old Oct 30, 2005 | 06:36 PM
Gran Patron's Avatar
Very helplful information! Thanks.
Old Oct 30, 2005 | 06:39 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Mine stuck out on the crank but Im going with an aftermarket crank anyway. Good info though.
Old Oct 30, 2005 | 06:43 PM
parish8's Avatar
good point, you can still use the block to build a motor with. one other thing is if you are going with a 4l80e then the crank will work but i would still try and avoid building anything with that crank just becasue it would be hard to sell later to anyone.
Old Oct 30, 2005 | 07:19 PM
greentahoe's Avatar
thank you
