Idle?????????
Old Nov 19, 2007 | 01:57 PM
05Silver5.3's Avatar
Default Idle?????????
What is a stock 5.3 suppose to idle at? Mine idles @ 500rpm to 550 rpm. And sometimes it drops down to like 400rpm amd feels like it wants to kill of me. Is this normal or are my cats clogged.
Old Nov 19, 2007 | 05:36 PM
2001si3rr@'s Avatar
Assuming you are talking about your 2005 Silvy? I'd take a look at your TB and get all the carbon cleaned out of it. Also take a look at your plugs and wires. You should get a code if it was your cats...
I'm leaning towards your TB being dirty!!!
Old Nov 19, 2007 | 06:30 PM
truckmann's Avatar
Stock idle in my 03 tune at operating temp should be ~550 in park/neutral. Should not stumble much below that though.
Old Nov 21, 2007 | 09:10 AM
I just cleaned my TB about a monthn ago and my spark plugs only has about 5k miles on them. It is not throwing a code for my cats.
Old Nov 21, 2007 | 09:30 AM
TarheelZ's Avatar
FWIW, mine idles fine @ just under 400rpm.
Old Nov 21, 2007 | 09:48 AM
truckmann's Avatar
I think if the cats were clogged you would be having a few other problems like being a real dog on power. Just off the top of my head you might check the fuel pressure regulator.
Old Nov 21, 2007 | 11:41 AM
sometimes it feels like something is holding it back when iam going down the hiway. how would i go about checking my fuel pressure regulator
Old Nov 25, 2007 | 02:49 PM
Texas Terminator's Avatar
11 Second Club
that idle is normal. what is the temperature? how many miles are on it? does it stink like rotten eggs? no? not your cats. have you ever changed your fuel filter? what kind of plugs did you put in it? does it idle ok? does it smoke when you drive? if so, when? are there any codes at all? is your e-brake sticking? you check your regulator with a fuel presure gauge connected to the test port on the passenger side fuel rail with the engine running, pull the vacuum line off and the pressure should jump up about 5-8psi. i doubt it's your regulator. does it knock or ping? that could be a sign of low fuel pressure.
Old Nov 25, 2007 | 03:12 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Totally normal. Mine used to idle at ~500 rpm and had a light shake. IMO the idle is too low from the factory. After I got my first tune I definitely noticed how much smoother it idled.
Old Nov 25, 2007 | 03:22 PM
jakebdb56's Avatar
same here, I set my idle to around 700'ish now and it's perfect
Pimpinpete
43
Dec 22, 2017 08:13 AM
bearden86
26
Nov 15, 2015 03:58 PM
BlownHD
Oct 3, 2015 12:24 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
01silvy
Sep 26, 2015 10:20 PM
