IC is whistling????
Old Oct 26, 2004 | 08:49 PM
jnybbad's Avatar
Default IC is whistling????
I just installed an air to air intercooler on my STS powered truck. When I step on the gas it whistles. Anyone know why!!! Now it really sounds like a jet comming down the street!!!
Old Oct 26, 2004 | 08:51 PM
99Silver6.0's Avatar
Hole in IC?? Burst seam on IC?? Hole in air-to-air boot?? Just throwing those out there.
Old Oct 26, 2004 | 10:19 PM
greentahoe's Avatar
Thats what Im thinking. Are you using T bolt clamps or regular clamps?? Sounds like you have air escaping somewhere.
Old Oct 26, 2004 | 10:41 PM
jnybbad's Avatar
Im using regular hose clamps. Ill have to check the connections tommorrow eith soapy water while tyhe engine is on. The IC is brand new and was pressure tested so it should be good!!
Old Oct 26, 2004 | 10:44 PM
You might wanna head to a Kenworth or Freightliner dealer and snag some actual intercooler clamps that have a spring in them. I dont think normal hose clamps will cut it. You can put soo much more tension on the t-bar clamps..
Old Oct 27, 2004 | 02:02 AM
lm7's Avatar
lm7
i just picked some of these up, anyone running an FI setup should be picking these up saves the headaches of having to pull over after a WOT pass to put your piping back together
71 Rat
Sep 24, 2025 12:15 PM
Infernohoe
48
Oct 2, 2015 10:25 PM
moregrip
Sep 9, 2006 11:39 AM
2003Silvyrado
Dec 1, 2003 03:03 PM
