IC is whistling????
I just installed an air to air intercooler on my STS powered truck. When I step on the gas it whistles. Anyone know why!!! Now it really sounds like a jet comming down the street!!!
Originally Posted by 99Silver5.3
Hole in IC?? Burst seam on IC?? Hole in air-to-air boot?? Just throwing those out there.
Im using regular hose clamps. Ill have to check the connections tommorrow eith soapy water while tyhe engine is on. The IC is brand new and was pressure tested so it should be good!!
You might wanna head to a Kenworth or Freightliner dealer and snag some actual intercooler clamps that have a spring in them. I dont think normal hose clamps will cut it. You can put soo much more tension on the t-bar clamps..
GXPJAY
Jan 27, 2016 11:45 AM
