I think it's about time to change the oil...
Old Mar 29, 2010 | 05:31 PM
AdioSS's Avatar
12 Second Club
Default I think it's about time to change the oil...
I've been considering sending this batch in to be tested to see if it really is a good idea to trust the built-in meter...
Old Mar 29, 2010 | 06:06 PM
budhayes3's Avatar
PT's Slowest Truck
Go for it man, and post up your results...I'm curious too. I'll bet that it checks out OK though
Old Mar 29, 2010 | 06:10 PM
slamdlsx's Avatar
mine has no meter boooo.
Old Mar 29, 2010 | 06:15 PM
Dewey's Avatar
I'm pretty sure that's only on the 03+ models. i think you should go to synthetic and see if it makes a difference in the meter's readings.
Old Mar 29, 2010 | 06:33 PM
jiar577's Avatar
I did it and makes no difference on the reading.
Old Mar 29, 2010 | 06:41 PM
Dewey's Avatar
ok then my vote goes to no for trusting the reading's accuracy.
Old Mar 29, 2010 | 07:05 PM
00ChevyScott's Avatar
Wearin' da big hat
Better to change it early than late, that's what I say.
Old Mar 29, 2010 | 07:13 PM
slamdlsx's Avatar
Mines an 04 I thought it would have it but guess not
Old Mar 29, 2010 | 07:15 PM
Wearin' da big hat
03-04 still had the limited cluster stuff I believe. 05+ got all the cool stuff, bastards.
Old Mar 29, 2010 | 08:16 PM
MikeGyver's Avatar
My 2000 just says CHANGE OIL (!)
GM says oil life is determined by:
1. How long you are at what rpm,
2. How long you are at what throttle position, and
3. How many miles.
So if you never rev it over 2000, never give it more than 25% throttle, it will probably be 10,000 miles before it tells you to change the oil.
Mine usually is 6000-7500 miles, which is fine by me since I only use Mobil 1 5w-30.
