I think I got ripped off by a shady mechanic
Old Jun 24, 2019 | 07:16 PM
Michael Orellana's Avatar
Registered User
Default I think I got ripped off by a shady mechanic
I took my truck to a bs mechanic for engine rebuild unfortunately, i know already off to bad start, however i cant notice my 212/218 cam with 114 lsa everything on my 08 sierra 1500 is stock is this normal or should i atleast have a lope or could a tune kind of make it this way im 5050 with this guy actually doing the work so im just wondering if a lh6 with 212/218 114 lsa stock exhaust is noticeable and to what extent
Old Jun 24, 2019 | 07:28 PM
arthursc2's Avatar
The best way to tell will be with a dyno run. The cam should be audible at idle, and it should pull all the way to redline, getting faster until 6-6200. Stock starts to die off like 5k IIRC
Old Jun 24, 2019 | 09:03 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Stock cam falls flat on its face at 5200 RPM.
The cam you mentioned should be barely noticeable at idle but should pull to 6k.
Old Jun 25, 2019 | 07:13 AM
Registered User
Thanks ill try and let you know would stock mufflers make it even less noticeable?
Old Jun 25, 2019 | 07:45 AM
arthursc2's Avatar
I (for sure) have the the 212/218 .550 on 112LSA, and my truck used to have the 6.2 OE muffler 3.5"IN 3.375"OUT, and it was noticeable. Now I have a Magnaflow 12909 in her, and its mellowed out the pulses and calmed the "booming" that used to occur at idle. I can still hear the cam, over a stock truck. But to quantify the difference, you would really have to have a stock truck there to listen to
Take note, my set up is the same, but a little different. My 112LSA will be choppier at idle (vs your 114), I have long tubes, full 3.5" exhaust, off-road Y
Edit: If the truck hasnt been tuned, get that done ASAP
Old Jun 25, 2019 | 08:24 AM
Registered User
It is tuned from what the guy said who worked on truck which was a friend of a friend it rides nice for a supposed rebuild had a lot of issues getting truck back and to run correctly as far as oil pressure, pcv was the old one so it was smoking horrible and well now its running better still get a tick or knock at startup when cold. After that no more tik and or knock oil pressure after getting pump shimmed sits around 40 good take off it goes up to round 60 and after a couple hours driving goes down to 25-30 with ac on. I think i got scammed but heres a link of how it sounds everything besides cam should be stock with dod delete
Old Jun 25, 2019 | 08:36 AM
arthursc2's Avatar
I'll watch that tonight with headphones on. Work PC speaker is pretty garbage
Old Jun 25, 2019 | 09:06 AM
Registered User
Sounds good thanks
Old Jun 25, 2019 | 11:16 AM
1994Vmax's Avatar
Doesn't sound stock for one of those. If he left the original cam in the truck it would be misfiring because of the stock afm cam. Pretty sure you didn't get scammed and why you keep saying that is interesting....
Old Jun 25, 2019 | 12:07 PM
arthursc2's Avatar
Scams happen, he listed some of the problem he had with a rebuilt engine. So while we may argue about the definition of a scam, if his post is truthful (I have no reason to believe its not) then he didnt get a drop in ready motor. And he was probably promised a drop in ready motor; aka scammed
Meanwhile, why do you say it would misfire at idle with the AFM cam? My AFM G8 didnt misfire at idle, so why would the 5.3?
