i think i am making more power now. tranny let go.
Old May 19, 2005 | 09:04 AM
  #21
zippy's Avatar
i certainly give cm motorsports some credit. their 408 held 7500rpm with some boost in the cylinder. for an engine with a 4" stroke that's pretty damn awsome.
Old May 19, 2005 | 09:57 AM
  #22
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Originally Posted by parish8
"chuck can rebuild it...better than before" it will be the bionic transmission.
na-na-na-na-na-na-na (think Steve Austin)
Old May 19, 2005 | 10:05 AM
  #23
01Blackerado's Avatar
Wow I never thougt it would happen with the ole 80e. Thats impressive... So Chuck said he can definatley make it stronger right??
Old May 19, 2005 | 02:50 PM
  #24
vanillagorilla's Avatar
I'd hold out for GM's new 6L80e......hehehe.
So is this the first blown "built" 80e we've had. Not to many 80e's bit the dust, let alone a built one. Interesting, everything has its limits, and I think we just found the 80e's.
Old May 19, 2005 | 03:06 PM
  #25
I cant believe you broke a built 80, but the stock axles and stock G80 are fine. WTF is up with that? I just cant believe nothing on the stock suspention has broke yet.
Old May 19, 2005 | 04:27 PM
  #26
zippy's Avatar
that's one impressive gov-lock.
Old May 19, 2005 | 04:42 PM
  #27
moregrip's Avatar
what a rush!
you ain't kidding
Old May 19, 2005 | 05:00 PM
  #28
G80 is probably coated in JB weld, makes it bomb proof
  #29
parish8's Avatar
single digit dreamer
i think chuck uses the tranzgo kit but it has lots of other parts in it too. i remember chuck mentioning one part that cost $600, can't remember what it was.
chuck sent me an email and is sending a box out. he said he kinda wanted to see what it was looking like in there anyways. from my past experience with chuck he will find the problem and come up with a solution to whatever broke, some way to make it stronger or apply less of an impact on it. all i know is i want pic's of whatever it was. probably some little clip or something silly.
here is a screen shot of the log.
Old May 19, 2005 | 05:43 PM
  #30
parish8's Avatar
just talked to chuck. he is thinking input shaft may have let go.
he says he cryo treats all his input shafts now but he didn't do mine since it was the first one he did. he is going to try a new shaft and cryo it and if that doesn't hold then he is going to have a stronger one made.
looking at the log file i think my drive by wire saved the motor from reving higher. i see where the throttle closed and the rpms came down to 6900 then it started to open again before i let off. i dont think i have a fuel cut anymore and i dont know if i want one either.
