I still hate my truck
Old Jul 15, 2008 | 12:02 AM
drkblusierra's Avatar
Default I still hate my truck
i have finally got my wiring harness for my walbro inline pump today, at first the pump didn't want to turn on, i double checked everything and it started working.... i can hear the pump turn on when i turn the ignition, the truck will start after the second crank of the ignition slugish like. i checked the fuel pressure and it sits just below 40 psi with a little throttle it will climb just above 40 psi the truck will sit and idle and the pressure will drop to about 35 psi. So would this be because my stock intank fuel pump isn't feeding enough pressure to the inline pump? where should i go next with this? also before the inline pump my fuel pressure would sit at between 27-30 psi so there has been so improvement with the inline pump...
Old Jul 15, 2008 | 12:11 AM
KySilverado's Avatar
Simple system. Pump,relief valve (FPR) and filter. Your fuel pressure is to low. Don't think of the pump feeding "pressure". It feeds volume/flow of fuel. Pressure is resistance to flow and regulated with the FPR. Since your pressure climbed a little with the new pump I would say the intank pump or the filters.
Old Jul 15, 2008 | 12:29 AM
the fuel filter i replaced, im not too famillar with the in-tank fuel pump since, well all of this is pretty new to me, i did not change out the fuel pressure regulator, could this be part of the problem too? thanks for the help on this.
Old Jul 15, 2008 | 01:21 AM
Wheatley's Avatar
Truck Sponsor
Yes it could be
Change that also
Old Jul 15, 2008 | 11:53 PM
i changed my FPR and what would you know, almost 60 psi of fuel pressure. it made me damn near **** myself watching the pressure gauge. Ive got to thank charlie wheatley for not only his advice but putting up with my emails crying about my truck. great customer service. thankyou
Old Jul 16, 2008 | 08:29 AM
Dirty 30's Avatar
LS1Tech Whore
Which FPR did you replace?
Old Jul 16, 2008 | 06:00 PM
the fuel pressure regulator. I spoke too soon though threw code po300 now, truck seems to run fine though. more investigating to do...
Old Jul 16, 2008 | 07:01 PM
Dirty 30's Avatar
LS1Tech Whore
i should have asked, where is it located?
Old Jul 16, 2008 | 07:20 PM
oh sorry off the fuel rail on the intake manifold
wrb002
Aug 31, 2015 12:00 PM
Ketis
Jul 23, 2015 12:37 PM
Suburban2500
Jul 19, 2015 04:50 PM
black6spdz
Jul 16, 2015 01:32 AM
ALynch
Jul 6, 2015 09:49 AM
