A.I.R & EGR Headers?
Old Oct 20, 2005 | 01:54 PM
anarchyracing's Avatar
Question A.I.R & EGR Headers?
im trying to pick up a set of shorty headers for my 4.8 4x4 to add to the no muffler, dual exhaust w/ X pipe setup im running. i seem to run into the question of wether i have A.I.R & EGR . can someone tell me what that means and how the best way to detect if i have either or neither on my truck?
BlownChevy's Avatar
blownerator
25 Year Member
year of the truck?
Old Oct 20, 2005 | 01:57 PM
its a 1999
Old Oct 20, 2005 | 02:38 PM
budhayes3's Avatar
PT's Slowest Truck
You should have EGR, may or may not have AIR. EGR will be on the passenger's side exhaust manifold, there will be a pipe going from the ex manifold to an electronic valve, to the intake. If it has AIR, there will be an AIR pump with more ports going to both manifolds I believe...if you only see the EGR on the pass side, that's all you have.
FWIW, I wouldn't waste my money on shorties, I'd go for a good set of long tubes. I have shorties myself and the gains are very little to none. I'm saving up for some LT's.
Old Oct 20, 2005 | 02:51 PM
as much as id luv to run long tubes ive been told that id have clearence issues because of it being a 4x4. are there certain long tube headers that would actually fit?
Old Oct 20, 2005 | 02:55 PM
BlownChevy's Avatar
blownerator
25 Year Member
I am willing to bet you have AIR and EGR on that truck.
Old Oct 20, 2005 | 07:22 PM
budhayes3's Avatar
PT's Slowest Truck
My 99 doesn't have AIR...I think it depends if it has Cal or Fed emissions? I haven't seen too many NBS trucks with AIR personally, might have to do with being East Coast.
ASM's will fit, but require minor cutting and welding of the y-pipe. The Dynatech system will also bolt right in, and I've heard that the StainlessWorks will fit if you delete the EGR and AIR (if equipped).
Old Oct 20, 2005 | 07:48 PM
stone150's Avatar
what about an 01 z71 5.3l?
Old Oct 20, 2005 | 08:54 PM
dewmanshu's Avatar
Moderately Differentiated
i got the dynatech and mine is 2K. The first install my front DS hit the collector. and took a nice chunk out of it. Dynatech replaced it (they don't cover labor...as who does?) and with a wood 2X4 as a pry bar I shoved it against the outer wall and I'll tell ya...it's F-ing close, but it's been golden since. It sucks...the clearance, but from what I gather, you'll be happier with LT's.
I don't have AIR either. HAD EGR...trashed that recently.
Old Oct 20, 2005 | 08:57 PM
budhayes3's Avatar
PT's Slowest Truck
Same as the 99...ASM and Dynatech definitely...and I'm hoping StainlessWorks (those are the one's I want)
