I need your help/advice
Old Dec 29, 2009 | 05:42 PM
ajohn6's Avatar
Default I need your help/advice
I just bought an '06 6.0L and 4L60e on the cheap cuz this guy lost interest in his project. He bought it in late '07 and it has very low miles. I am going to put it in my '71 C10. The motor/tranny has been sitting in his garage for the last two years with nothing done to protect them. The tranny cooler lines were removed and not plugged up and a couple spots on the motor weren't plugged either. I believe the PO had washed the motor before I came and picked it up.
Due to the fact they have been sitting for two years and they possibly now have moisture in spots they shouldn't, what steps should I take to make sure these things don't fail when I do get them installed?
Thanks in advance,
Adam
Old Dec 29, 2009 | 05:44 PM
03chevyroyce's Avatar
what parts of the motor were left uncovered?
trever1t's Avatar
2nd fastest 5.3 ECSB
Drain, flush everything.
Old Dec 29, 2009 | 05:53 PM
ajohn6's Avatar
The throttle body was stuck open and the oil cooler lines were on but not plugged.
The PO said everything was drained when he got it. The motor spins like it should and I want to check the compression of each cylinder but I don't know how to do it. Can it be done just by turning the crank by hand?
Old Dec 29, 2009 | 05:58 PM
fill it with oil
and pull the intake manifold and see if any dirt, debris, or dust got in
Old Dec 29, 2009 | 06:12 PM
ajohn6's Avatar
Cool, thanks for the help guys.
Do you guys think it is worth while to do a compression check?
Old Dec 29, 2009 | 06:23 PM
yeah it is
try to blow out the cylinders with compressed air first just in case there is anything in there
Old Dec 29, 2009 | 06:30 PM
terravast4's Avatar
was the trans stored full of fluid? if not there could be issues internally with parts drying out.
Old Dec 30, 2009 | 07:55 AM
Raffman's Avatar
Pull the intake. With the cathedral ports you can see the valves, check for critters.
Richardman1992
Mar 26, 2014 04:56 AM
Pottsie
Mar 28, 2013 02:11 PM
BIGDADDY1969
Mar 5, 2013 04:36 PM
Dwl9113
Dec 19, 2012 06:09 PM
Silver05Rst
Oct 10, 2012 05:28 PM
