I need to rebuild my bigblock with one of these!!!!!
Old Jan 30, 2005 | 11:32 PM
Default I need to rebuild my bigblock with one of these!!!!!
http://www.sallee-chevrolet.com/Chev.../12370850.html
combine that with the raylar heads and intake ...and sts....and Id be stylin
Old Jan 31, 2005 | 12:11 AM
That block won't work with 8.1 or raylar heads.For performance applications that block can be built into a 1000+ monster,the ZL-1 aluminium big block, showed up in the late 1960s to dominate NHRA superstock and the old CanAm roadracing series.
Old Jan 31, 2005 | 01:11 AM
BurnOut's Avatar
Really and truly, the flow numbers on the Raylar heads aren't that impressive... they'd be impressive for an LSx motor, but we're talking about nearly 500 inches here. For big block heads, I'd look at Pro Action or AFR (for off-the-shelf pieces).
Old Jan 31, 2005 | 11:56 AM
Are you sure??? I though a while ago some one did some conversons with a big block and found the the blocks and such were the same for the 8.1 and the BBC, the only real differnce being the intake, and the heads that match them but the heads bolt to the block like regular BB heads. ( oh and the firing order on the cam shaft as the firing order on the crank is the same just due to the cam parts of the crank get moved from the exhaust stroke to the intake and visa versa )
03sierraslt
14
Oct 9, 2015 05:53 AM
gmcyukon
Oct 5, 2015 06:20 AM
trevorh1
Sep 27, 2015 08:47 PM
sTNT971
Sep 26, 2015 06:27 AM
97aztecgt
Sep 10, 2015 05:07 PM
