i need help with picking one form of stroker
Old Jan 23, 2006 | 01:28 PM
white1's Avatar
Id say 408, but I perfer to make as much power as possible N/A. Though I have been thinking of a turbo or two on the 6l
Old Jan 23, 2006 | 01:37 PM
MikeGyver's Avatar
Originally Posted by 4.8T
if i have to spend money on the block then that takes away from the turbo fund which i have everything for but piping thats all i really like and an oil pump maybe depends on where i put the turbo. so if i go 6.0 i may not be able to get my turbo in till like this time next year.
This time next year, turbo or not, you're gonna wish you started out with a 408.
Old Jan 23, 2006 | 02:05 PM
dkota196800's Avatar
Check out lingenfelter and SLP for whole new short blocks. LPE has redone LS1 short blocks with forged pistons for 2000 dollars. SLP has the 402's cast iron or aluminum blocks with good prices. If money is no option go for the LPE 427 short blocks.
Old Jan 23, 2006 | 02:23 PM
TURBHOE's Avatar
well money is a big issue or else i'd do both lol. i'm limited. about 3700 to get eng done weather it be turbo or stroker and tires and hopefully a camper shell. and i would like to get my damn bed fixed where my wife jacknifed it into a trailor. so there is my delima. for a grand i could get rods and pistons for the 5.7 and through the turbo on there and make loads of power i'm sure but will my heavy *** truck be better with the bigger motor and turbo later. i'm gonning on about two trips to arkansas this year which is about 1700 mile one way. hint the reason i need the camper shell. but which will hold up better to the trips the 402 iron block or a forged rod ans piston ls1 with the turbo?
Old Jan 23, 2006 | 02:38 PM
white1's Avatar
Id say the 402, if youre buying the short block, I doubt the 408 cost mutch more if any.
Old Jan 23, 2006 | 02:59 PM
TURBHOE's Avatar
well i was going to buy a bare block and buy the parts. its about 2070 for parts then the block is about 699 or so.
Old Jan 23, 2006 | 03:52 PM
TurboGibbs's Avatar
Since you already have the turbo i'd build what would be a good size engine for the turbo. Unless you bought it with the intentions of using it on the 4.8. What size turbo do you have?
Old Jan 23, 2006 | 04:16 PM
TURBHOE's Avatar
compressor: TO4R
.70 a/r
66.5mm inducer
flow: 75 lbs/min 960cfm
360* thrust bearing standard
turbine: T4
.84a/r
http://store.yahoo.com/cheapturbo/garrettt4to4r.html here is a link and i got the .84a/r i origanaly bought it for the 4.8
legerwn
56
Nov 15, 2015 10:21 PM
mitchellmade
Sep 27, 2015 08:25 PM
MOBBN
Sep 22, 2015 08:07 PM
ZxHybrid
Sep 18, 2015 04:44 PM
jtphelps289
Sep 11, 2015 06:37 PM
