I need help installing my boost gauge
Old Oct 3, 2002 | 09:58 PM
Default I need help installing my boost gauge
Ok, I removed my HVAC vent closest to the driver side window, I replaced it with a piece of Black ABS plastic and a flush mounted autometer boost gauge. I just dont know where to install the pressure tube that picks up the boost pressure. I dont know of any after the s/c so where does it go? Im going to call Magnacharger in the morn.
Old Oct 3, 2002 | 11:30 PM
Texas Terminator's Avatar
11 Second Club
Default Re: I need help installing my boost gauge
if you haven't used it for your FMU, take the intake cover off, on the passenger side of the intake, there is a tap coming out of it with a tab on the end. take a pair of flat pliers and snap it off and plug your gauge in there. no prob.
Old Oct 4, 2002 | 06:45 AM
L-EATER's Avatar
11 Second Truck Club
I put a "T" in the line going to the fuel pressure regulator on mine.
Old Oct 4, 2002 | 04:17 PM
I must have fucked up when i purchased the guage. The line that runs from the gauge is only an 1/8in line. If you blow air into the line, the gauge moves. I coneccted it to the fitting on the intake man. now the guage doesnt work. It doesnt move because of vaccuum. D they make a gauge that runs on vaccuum? not on pressure? <img border="0" alt="[Banging Head]" title="" src="graemlins/gr_banghead.gif" />
Old Oct 4, 2002 | 05:23 PM
BigTex's Avatar
Yep. You need a vac / boost gauge.
I installed mine in the brake booster line.
Old Oct 4, 2002 | 06:27 PM
parish8's Avatar
single digit dreamer
1/8" line is fine for a gauge, are you sure it is seeing intake presure? i wouldn't think it would hurt the gauge to put vacume to it, it would just read 0 when there isn't any boost. i have a 15psi fuel presure gauge that i am using for my boost gauge and when i am not seeing boost it just read 0
i didn't like any of the boost gauges that i could find, with just 6psi of boost there would be so little needle sweep it seemed week to me, i want the needle to sweep around when i hit it.
here are a few pic's of what i did. under the hood i put a tee in the line that goes to the pvc valve.
http://hometown.aol.com/cobra99vert/...ugephotos.html
Old Oct 8, 2002 | 08:17 PM
BigTex
Member # 1197 posted October 04, 2002 05:23 PM
Tex, What brand gauge/model number do you have?
chopperloco
Jul 10, 2016 10:45 PM
thunder550
Oct 8, 2015 04:53 PM
Ls3silverado
Jul 31, 2015 04:22 PM
FlowmasterMufflers
Jul 22, 2015 01:29 PM
