Anyone with TT 3000..question
Old Oct 7, 2002 | 10:20 PM
Black Blown 02's Avatar
Default Anyone with TT 3000..question
How much shift extension did you get with this converter over stock? Right now my shift points are at 5800, and it drops to 3800-3900 after the 1-2 shift with the stock unit. I have an ATI, torque management delete, and other basic stuff. How much more shift extension can I expect?
Thanks, Rob
Old Oct 8, 2002 | 10:30 AM
GMC SKI's Avatar
Default Re: Anyone with TT 3000..question
I would Highly recommend a Stall with the ATI procharger. I purchased a Yank 3000 stall and it really compliments the ATI unit
The only down side it that you'll need a Tranny rebuild pretty soon after you put the larger stall in with my expierence. My tranny last 3k miles before it started to hurt <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
You've done some Progamming with LS1 edit ?
I would rasie the shift points for sure from the stock 5600 to 6000rpm for sure you'l notice a big difference as the ATI is still making tonnes of power up there Just make sure you have enough fuel which you might not have ..As i have run out of injector at the top end of things
What else do you have done with your truck any details on it ?
Just curious as to what you have done with your setup as i have a 2002 with a ATI
Jim
Old Oct 8, 2002 | 04:52 PM
Ok, heres my setup...2002 reg cab short bed Z71--5.3--4.10--Eaton clutch posi(not g80)--Jba shorties--3"true duals--X-pipe--dual Magnaflows--custom(by me)cold air intake from under the bumper to back of procharger, with insulated heat shield--Ed wright pcm reflash--transgo shift kit.
14.7@93 on a 2.4 60" at 4400 feet elevation
How much does your TT3000 let rpm's drop between shifts? Where are your shift points?
Old Oct 8, 2002 | 08:20 PM
parish8's Avatar
single digit dreamer
i haven't been able to floor my truck for weeks so i can't help you with the shift points or rpm change but looking at you set up you will really benifit from a stall, i bet you will get the full .5sec that they advertize, maybe more.
