i need help
Old Mar 3, 2011 | 07:01 AM
94 guy's Avatar
Default i need help
i'm building a 408 stroker for a for a 2000 chevy truck. i putting a ls3 L92 topend on it. what throttle body can i run with the 2000 harness and the ls3 L92 intake? thanks
Old Mar 3, 2011 | 07:54 AM
Gadgetized's Avatar
2000 should be operated by a cable, so it shouldn't matter(I thought 2000 were all cable, maybe I'm wrong). If someone put a harness in it from a newer truck, and it is a DBW (drive by wire) then you will need a plug to convert the signal over from the truck throttle body. At that point you can pretty much run anything.
Old Mar 3, 2011 | 11:19 AM
94 guy's Avatar
the reason i'm not sure is were putting the motor in a 98 chevy truck that had a vortec. we have a 2000 harness and computer out of a truck.
Old Mar 3, 2011 | 02:42 PM
Amedee's Avatar
Pretty sure thats cable driven DBW wasn't till 03 I think someone correct me if Im wrong
Old Mar 3, 2011 | 02:45 PM
00buckshot's Avatar
Yeo 03 started the DBW in trucks, I think some tahoes and suvs had it in late 02, at least I think
Old Mar 3, 2011 | 03:45 PM
1Bear's Avatar
As has been previously covered, ETC (DBW) was introduced across the board (except vans) in 2003; however trucks and SUV’s with traction control had it as early as 2001. Some luxury trucks such as the 2001 GMC C³ and 2002 GMC Sierra Denali even had it without traction control.
