i have search but to no luck (6.0 cam choice)
I want to do something different besides the normal. tr, tsp cams i haven't heard to many trucks or members running a lunati so that's but the ones that have one likes them.
MASS seller approved
If u want to do something different then go with a custom spec cam. Pat G at the guerrara group really knows his **** and he will spec a cam that is tailored to what u want and the every little detail of what is going into it. It's only 25 dollars and he will spec u a cam that u take those specs and build a cam that's meant for exactly what u are looking for. Pat g has been spot on with most cams he recommends.
yeah you can run a set of 243 heads plus it will bump up your compression to 10.2.1 with 64cc
Heads and cam LQ4 - YouTube
Thats basically the same cam I'm running and I love it. Mine has slightly different specs and I had it done custom by Pat G. Its got a slightly wider LSA with a cam lobe that is designed to make less noise on the exhaust side.
